1. Seremedy's Avatar
    How high is everybodies average "android system" in the battery settings ?
    03-17-2016 11:39 PM
  2. Almeuit's Avatar
    As I sit here on the couch browsing the forums and doing stuff on my Chromecast.. This is what my stats are after taking it off the charger at work.
    This is with lighter data usage for me on mobile (about 2 GB of LTE).
    Attached Thumbnails android system-1458276151068.jpg   android system-1458276157848.jpg
    03-17-2016 11:42 PM
  3. Dom3stic_T3rrorist's Avatar
    Try turning your location settings from high accuracy (GPS, WiFi, and mobile data) to low power (WiFi and mobile data estimate of location) I just tried that a few minutes ago hopefully that helps a lot also change your WiFi and Bluetooth setting those also put a strain on your battery
    03-17-2016 11:49 PM
  4. Almeuit's Avatar
    Personally I'm okay with my stats. Fast charging / wireless charging solve any worry for me.
    I use the high location a lot for GPS, weather, and also smart lock. That way it works how I expect.
    03-17-2016 11:51 PM
  5. limitbreak09's Avatar
    Whats your usual SOT when you have your location turned on to high acc?
    -S7Edge
    03-18-2016 12:20 AM
  6. Almeuit's Avatar
    -S7Edge
    I've had some other good times but usually anywhere from 3 to 5 hours of usage a normal usage cycle.
    I am pretty heavy on phones usually. I used to do 100+ GB a month on LTE but lately it's been around 30-50.
    03-18-2016 12:27 AM
  7. Lobwedgephil's Avatar
    Mines been 20-30%, but not an issue, getting very good battery life.
    03-18-2016 12:39 AM
  8. Almeuit's Avatar
    Final before charging this morning.
    Attached Thumbnails android system-1458310231291.jpg   android system-1458310238401.jpg
    03-18-2016 09:10 AM
  9. D_Baine's Avatar
    I was having real good battery use. Like over a day on a single charge. Yesterday I noticed my battery draining pretty quick. I checked my usage and android system is pretty high. Anyone have any ideas why it shot up?android system-226.jpg
    03-18-2016 09:40 AM
  10. popkurn611's Avatar
    I am having massive drain from cell standby (48%). By the looks of the screenshots you posted and others no one even has cell standby in their list. Do you have hd voice on? I don't know why this is happening but it is killing my battery.
    03-18-2016 10:33 AM
  11. Almeuit's Avatar
    Yeah I use HD voice / VoLTE. I am on T-Mobile .. are you? If so, do you use WiFi calling?
    03-18-2016 10:36 AM
  12. popkurn611's Avatar
    I am on Verizon. I have wifi calling off. I don't understand why my cell standby is at 48% that is crazy
    03-18-2016 10:39 AM
  13. Almeuit's Avatar
    That is odd. Let me have one of our Verizon guys on the team come in and see if he is getting that on his S7 Edge.
    03-18-2016 10:41 AM
  14. popkurn611's Avatar
    I'd appreciate it, I have posted elsewhere and haven't received any feedback yet so I thank you for helping out
    03-18-2016 10:42 AM
  15. dpham00's Avatar
    This is what I am seeing on Verizon.
    Cell standby 48% seems high, unless you were idling most of the time
    Almeuit likes this.
    03-18-2016 11:00 AM
  16. popkurn611's Avatar
    Tell me about it, it's ridiculous. See below
    03-18-2016 11:05 AM
  17. Almeuit's Avatar
    https://uploads.tapatalk-cdn.com/2016...3ce40edf5e.jpg
    Hm.. I wonder if you're seeing it since you're on wifi. dpham doesn't go on wifi much so that may be why he isn't seeing it.
    03-18-2016 11:18 AM
  18. popkurn611's Avatar
    But I always have been on wifi with my android phones and haven't seen this issue, 46% is not normal
    03-18-2016 11:21 AM
  19. Seremedy's Avatar
    Very wierd. I have the same or very similar set up on my note 5, but the note 5 is at 3 percent android system, while my edge is at 30 ! Percent
    03-18-2016 04:11 PM
  20. ajp8806's Avatar
    My Note 4 was the same way, 5-10%, this phone is usually 25-30%.
    03-18-2016 06:03 PM
  21. meyerweb#CB's Avatar
    Remember that the total of all these battery percentages MUST add up to 100%. I looks like Marshmallow is dumping all battery usage that isn't directly attributable to a specific activity into Android System. My Android System battery usage is "high", but this phone is giving me better battery life than any phone I've had, so I;m not worried about it at all.
    Tatt2014 likes this.
    03-18-2016 08:22 PM
  22. gnuser's Avatar
    ATT guy.
    03-18-2016 08:46 PM
  23. meyerweb#CB's Avatar
    My usage today. Only day three with the phone, and I'm still doing a lot of app installs, configuring, and playing around. No heavy game play. I have been on WiFi all day. But I don't think I've EVER gotten 5 hours of screen on time on any other phone, so to get 5 hours SOT and still have nearly 50% left is fantastic.
    03-20-2016 10:30 PM
  1. Android M for lenovo K 3 note
    By emjey in forum Android 6.0 Marshmallow
    Last Post: 03-26-2016, 08:26 AM
  2. Android 6.0 update on Verizon Note 5 Major Issues, PLEASE HELP
    By KristenOtt in forum Samsung Galaxy Note 5
    Last Post: 03-19-2016, 07:47 PM
  3. My android tablet ares 11 says it has front and back camera.
    Last Post: 03-17-2016, 10:02 PM
  4. Android Central Push Notifications
    By TheRealFixxxer in forum General Help and How To
    Last Post: 03-17-2016, 09:07 PM
  5. Replies: 1
    Last Post: 03-17-2016, 08:52 PM
