03-23-2016 03:41 AM
48 12
tools
  1. eRod v1.0's Avatar
    Anyone else getting the update? I'm on T-Mobile and it's about 41mb.
    03-17-2016 06:59 AM
  2. eRod v1.0's Avatar
    Forgot to add screenshot. It looks like the security update.
    03-17-2016 07:01 AM
  3. Dm1120's Avatar
    Just got a software update. It said it would take 10 minutes to install but really took 30 minutes.
    03-17-2016 07:05 AM
  4. Dm1120's Avatar
    Got it. No idea what it fixed but it took forever to update.
    03-17-2016 07:08 AM
  5. daddyd302's Avatar
    Thanks for the heads up. I had no idea there was an update.
    03-17-2016 07:10 AM
  6. anon(5719825)'s Avatar
    I just got it on mine. I hate when they don't tell us what the update does.
    03-17-2016 07:25 AM
  7. Almeuit's Avatar
    I haven't got it yet but for those who did.. Check your security patch date. The phone came with February so see if it updated.
    03-17-2016 07:34 AM
  8. Almeuit's Avatar
    And I take that back... Need to charge real quick though .
    03-17-2016 07:35 AM
  9. anon(5719825)'s Avatar
    The update takes a lot of time optimizing the apps.
    Liskrig likes this.
    03-17-2016 07:38 AM
  10. anon(5719825)'s Avatar
    Still shows February 1, 2016 as security update.
    03-17-2016 07:44 AM
  11. daddyd302's Avatar
    Well this is great! The update just wiped out all my apps stored on the SD card..... All the non color looking apps were on the SD and now it's gone.....
    EDIT: After 10 minutes the apps came back, very odd.
    Kilroy672 likes this.
    03-17-2016 07:46 AM
  12. SpookDroid's Avatar
    Did it say what changed? Traveling right now, so not too keen on installing updates haha
    03-17-2016 07:50 AM
  13. brava27's Avatar
    LOL who uses stock launcher?
    03-17-2016 08:14 AM
  14. daddyd302's Avatar
    If you look closely at it, it's not stock.... It's Nova with the stickers theme......
    03-17-2016 08:26 AM
  15. brava27's Avatar
    True oops
    03-17-2016 08:31 AM
  16. anon(5719825)'s Avatar
    I use the stock launcher and have on all of my Android phones. I tried Nova once on my first Android phone. I set up Nova and removed it about an hour later and never went back.
    Not Quite Right likes this.
    03-17-2016 08:45 AM
  17. DaveInFL's Avatar
    I use stock too, so what? I'm coming from the HTC One M8 and that was stock too. Then again, Sense is probably the best stock front end out there.
    03-17-2016 09:23 AM
  18. Bryant Laney's Avatar
    Got mine about an hour ago.
    03-17-2016 09:25 AM
  19. Almeuit's Avatar
    I didn't mind the "Blink Feed" or whatever it was when I had the M7 back in the day but I still wasn't a fan of Sense. To be honest I wasn't a fan of most launchers so I just used Nova to tweak it how I like. I am now using the Google Launcher on my phone .. I blame it on my Nexus 6P which caused me to use it by default and I just stuck with it. Now I have grown accustom to it haha.
    03-17-2016 09:26 AM
  20. Bryant Laney's Avatar
    I got my update about an hour an ago.
    03-17-2016 09:27 AM
  21. bhatech's Avatar
    I like Google now launcher as well but on the S7 edge the icons looks comically big and can't change the grid size from 4 columns. That's a bummer and for that reason I switched back to Nova on S7 edge but kept the GNL on 6p.
    03-17-2016 09:52 AM
  22. anon(9013794)'s Avatar
    I got the update about 30 minutes ago, haven't noticed anything changed
    03-17-2016 09:56 AM
  23. DaveInFL's Avatar
    Just gone through the update. It did take quite a while to optimise the apps. Phone on charge will play with it later.
    Would be great to know exactly what this update did though.
    03-17-2016 10:59 AM
  24. Almeuit's Avatar
    The only thing I have noticed so far is a Baseband difference.
    Liskrig and srkmagnus like this.
    03-17-2016 11:10 AM
  25. bhatech's Avatar
    Could be just improvement in radios since I was seeing slower LTE speeds on the S7 compared to iPhone and my other Android phones in the same location. I'll test out later today to see if there is an improvement now.
    03-17-2016 11:22 AM
48 12
  1. LG V10 updates?
    By mattdamiz85 in forum LG V10
    Last Post: 03-18-2016, 08:54 PM
  2. how to update my a94 molibe
    Last Post: 03-18-2016, 08:53 AM
  3. T-mobile s6
    By Pmcanally37 in forum Samsung Galaxy S6
    Last Post: 03-18-2016, 01:48 AM
  4. Replies: 0
    Last Post: 03-17-2016, 11:49 PM
  5. Replies: 2
    Last Post: 03-17-2016, 11:02 PM
