From the reviews that I've read, it doesn't support quick charge 2.0. Here are a few Pro's and Con's that I've found out about this charger:
Cons:
No specs found on website or any other site. Reviewers say that it doesn't quick charge any of their qc 2.0 compatible phones.
Some people report that the micro stick pad is not sticky enough even on smooth cases. It also less effective when your car heats up or if the pad gets dirty.
Some people say also say that the magnets in it aren't strong enough even after you put on the magnetic sticker that comes with it. (could be a nexus 6 issue with it's curved back)
No vent mount option. (What I'm looking for)
Expensive. $99 (get $25 off with their spring discount code)
Not quick charge 2.0 compatible
Pros:
Wireless, cradle-less, and works for Qi compatible phones.
Cd mount option available. Standard mount works for smooth or textured surfaces.
NFC chip built in.
Well I'm still looking for something similar to this. I'd prefer if it was QC 2.0. I currently have a magnetic vent mount in my car and the s7e sticks to it even with a spigen slim case.
There are plenty of wireless Qi car chargers on Amazon and even with QC 2.0. But all of them have cradles or some type of ugly clamp system. If anyone finds something similar to Air Dock 2.0, please let me know. Thanks!
Some reviews that I found:
http://bestwirelesscharger.org/the-air-dock-review/ http://www.reddit.com/r/nexus6/comme...ved_yesterday/ http://esbuzz.net/trends/video/the-a...ndroid--iphone
