03-23-2016 10:42 AM
51 123
tools
  1. bsannes's Avatar
    Any body have an idea what it is for?
    03-18-2016 11:41 AM
  2. dpham00's Avatar
    Just got notification on my phone now.
    03-18-2016 11:42 AM
  3. bchain996's Avatar
    looks like a security update?
    03-18-2016 11:42 AM
  4. tomatosouplabs's Avatar
    It just downloaded now, have no idea.
    edit: so much for checking heat on my phone, it's burning a hole in my pocket optimizing apps right now.
    03-18-2016 11:45 AM
  5. VDub2174's Avatar
    03-18-2016 11:48 AM
  6. bsannes's Avatar
    Just saw that after I posted this.
    VDub2174 likes this.
    03-18-2016 11:53 AM
  7. PJRed2008's Avatar
    Mine just finished, took less than 15 minutes, most of that 'app optimization'. All appears to be well.
    03-18-2016 11:55 AM
  8. kmod75's Avatar
    It's still the same February 1st security update that the phone came with. Wonder what changed???....
    03-18-2016 12:02 PM
  9. Mike-Mike's Avatar
    i got mine with a manual check, Optimizing app screen takes forever
    03-18-2016 12:15 PM
  10. sfldg's Avatar
    Make sure you enable all packages that you have disabled before running the update
    03-18-2016 12:16 PM
  11. bchain996's Avatar
    before
    03-18-2016 12:19 PM
  12. bchain996's Avatar
    After. Only difference I can tell is my phone burnt my hand as it was finishing and I picked out up and lost 18%
    03-18-2016 12:19 PM
  13. sangs's Avatar
    Or what happens? I ask because I didn't re-enable any packages that I've disabled, yet the update went through and everything is fine. And Package Disabler Pro still shows those packages as disabled following the update.
    03-18-2016 12:22 PM
  14. DFranch's Avatar
    I forgot, seems to be ok. What's the downside?
    03-18-2016 12:23 PM
  15. tomatosouplabs's Avatar
    build date of the kernel changed to march 10
    03-18-2016 12:29 PM
  16. jpdaballa's Avatar
    I have adoptable storage enabled so I'm going to wait a little bit and do some digging
    03-18-2016 12:35 PM
  17. wxman2003's Avatar
    Updated. Still does not allow us to use Samsung web browser.
    03-18-2016 12:51 PM
  18. bsteppuhn's Avatar
    I didn't even think of it either
    03-18-2016 12:53 PM
  19. lady of the lake's Avatar
    Got update 30 minutes ago. What is the "Samsung browser" an earlier poster mentioned?
    My Spectacular Samsung Galaxy S7Edge
    03-18-2016 12:56 PM
  20. wxman2003's Avatar
    It a great browser with adblock. For some reason, Verizon does not allow Samsung's own browser to work on this phone. You can't download it from the app store.
    greenplum likes this.
    03-18-2016 12:58 PM
  21. sfldg's Avatar
    My guess would be the update has problems if its updating certain packages that are disabled? I just know the app developer recommends it, not sure if there is a drawback to not enabling them
    03-18-2016 01:07 PM
  22. PJRed2008's Avatar
    That's because its just a security update.
    03-18-2016 01:13 PM
  23. felloffthetruck's Avatar
    So, It's safe?
    Does it fix the SD Card notification problem?
    03-18-2016 01:30 PM
  24. kami8586's Avatar
    I have noticed significantly slow fast charging, also made sure to check fast charging was enabled in settings.
    S7 Edge Titantium
    03-18-2016 04:47 PM
  25. jimbo1mcm's Avatar
    Update turns Marshmallow into Lollipop because Verizon needs to be always 3 updates behind. Just kidding.
    03-18-2016 04:55 PM
51 123
  1. Replies: 4
    Last Post: 07-20-2016, 04:39 PM
  2. Replies: 1
    Last Post: 03-31-2016, 04:21 PM
  3. Activating on verizon
    By phillyphreak in forum Moto X Pure Edition
    Last Post: 03-18-2016, 02:43 PM
  4. Update from Verizon
    By bsannes in forum Samsung Galaxy S7
    Last Post: 03-18-2016, 12:29 PM
  5. Why can't my S7 stay connected to internet' via wifi?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-18-2016, 11:27 AM
