04-26-2016 02:04 PM
33 12
tools
  1. mattjewell15's Avatar
    No, the Game Launcher is separate from that. Ex: I still have the option turned on to block notifications will in game.
    You're the man. So with those two services and others that you've disabled, have you noticed a difference in battery life or performance?
    03-18-2016 03:02 PM
  2. Adiliyo's Avatar
    mine was super laggy after the update completed, but after 5-10mins now it seems to be running like before.
    also if you have adopted storage enabled, the update does not mess with it.
    03-18-2016 03:16 PM
  3. TMavC5's Avatar
    Something did happened to my phone before update. Screen locked and apps were missing but eventually everything went through without any issue. It took about 20 minutes before settling in.
    03-18-2016 03:18 PM
  4. jaltman's Avatar
    Baseband updated, "security enhancements" date updated to March 10, but security level remains February. So, while it appears to be security related, it is not THE Monthly security update.
    03-18-2016 03:26 PM
  5. AlphaVictor87's Avatar
    I haven't, I still get all day battery with about 5h SOT
    03-18-2016 03:35 PM
  6. Akramer77's Avatar
    Looks like an update is available for the AT&T variants as well. Mine is just in the process of rebooting. The update was about 40MB.
    So since I did the update my husband and both are having bluetooth connection issues in our cars. It will connect play and work for approximately one minute and then then stop. But when you look in settings it shows still connected
    04-25-2016 10:03 PM
  7. will083006's Avatar
    My Messages app stopped working after the AT&T update. When I open messages and click on a single person-to-person existing test, it closes and gives me the error "Unfortunately, Messages has stopped working". What's weird is that it DOES NOT do this for group messages. HELP!!
    04-26-2016 12:45 PM
  8. paridge's Avatar
    You might have to wipe the cache partition.
    04-26-2016 02:04 PM
33 12
  1. Replies: 4
    Last Post: 03-20-2016, 10:57 PM
  2. Data Transfer onto The Samsung Galaxy S 7 Edge
    By Guapa111 in forum Samsung Galaxy S7 edge
    Last Post: 03-19-2016, 08:18 AM
  3. Replies: 3
    Last Post: 03-18-2016, 02:29 PM
  4. Wifi and Email Problem on S7, how can I fix this?
    By acambridgegal in forum Samsung Galaxy S7
    Last Post: 03-18-2016, 12:06 PM
  5. AT&T Out With a Security Update
    By Scutley in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 12:03 PM
