04-26-2016 02:04 PM
33 12
tools
  1. pgood4's Avatar
    Looks like an update is available for the AT&T variants as well. Mine is just in the process of rebooting. The update was about 40MB.
    03-18-2016 08:39 AM
  2. djohn22's Avatar
    I got mine this morning. Installed quickly and no bugs so far. Seems it most mostly a security update. I was worried about how hot the phone got while updating, but it cooled off after and is running fine now.
    03-18-2016 08:58 AM
  3. pounder001's Avatar
    Thanks just checked and mine is downloading right now
    03-18-2016 09:12 AM
  4. Thiscrapsucks35's Avatar
    It just finished updating.
    Phone is now laggy as @#$%. Unless this update is critical, be wary.
    03-18-2016 09:20 AM
  5. pounder001's Avatar
    No difference for me?
    03-18-2016 09:22 AM
  6. Thiscrapsucks35's Avatar
    Consider yourself lucky then.
    I'll probably have to wipe and re-do. It's terrible.
    03-18-2016 09:25 AM
  7. Thiscrapsucks35's Avatar
    I think I resolved it. It didn't seem to like apps I had installed on my sd card. Moving them back to the device seems to have resolved the issue.
    03-18-2016 09:37 AM
  8. Captpt's Avatar
    Anyone know what the update is for??
    Updating now, never saw Optimizing Apps take this long!!
    03-18-2016 09:39 AM
  9. gnuser's Avatar
    Glad to see they are on top of it. Need an update from Samsung now.
    03-18-2016 09:49 AM
  10. pinkvikchick's Avatar
    Mine was laggy too, I figured it was because my sd card was repopulating or whatever...seems fine now.
    03-18-2016 10:19 AM
  11. pgood4's Avatar
    Mine was a bit laggy for 5 minutes or so after the update, but back to normal now. My only observation is that it seems that the phone might be entering doze more often than before. Very early observations, but looking at GSAM Pro and I have a big flatline in consumption that I haven't seen before. Might just be that I'm using it a bit less today and will have to monitor over the next few days, but it does seem different in consumption.
    03-18-2016 10:52 AM
  12. rkkeller's Avatar
    Mine is installing right now, fingers crossed.
    03-18-2016 10:52 AM
  13. gtg465x's Avatar
    Installing now. Really hope this fixes the occasional freezing when playing some YouTube videos in 1440p.
    edit: Not fixed. Damn.
    03-18-2016 11:11 AM
  14. Scutley's Avatar
    Looks like AT&T is rolling out a security update for my Samsung S7 Edge. It said it's an AT&T update not Samsung.
    03-18-2016 12:01 PM
  15. Lobwedgephil's Avatar
    03-18-2016 12:03 PM
  16. Rheller82's Avatar
    Any chance it fixes the wifi/bluetooth issue?
    03-18-2016 12:13 PM
  17. mattjewell15's Avatar
    Just performed the newest update that was released this morning for AT&T.
    So far so good, I've noticed Clash of Clans isn't as dark anymore, thank goodness. It was hard to see.
    Coming from all iOS devices, they all now look the same (color wise)!
    Also, the screen mode has always been on Adaptive Display.
    Anyone else notice anything better?
    03-18-2016 12:48 PM
  18. gtg465x's Avatar
    Haven't had any issues with either even before the update.
    03-18-2016 01:00 PM
  19. gnuser's Avatar
    I don't think it was a OS update, it was something to do with network security. I would be surprised you are seeing better output in the phone.
    03-18-2016 01:06 PM
  20. AlphaVictor87's Avatar
    I'm going to have to check this out. It's currently on the optimizing app stage. I have Package Disabler Pro on so i'll have to re-enable the game services thing to see if it truly does change it back to being lighter. Will report back soon.
    03-18-2016 01:37 PM
  21. mattjewell15's Avatar
    Not too familiar with Package Disabler since I'm new to Android and Samsung, but did that help the darkness issue before? Just trying to figure out something in case it reverts back to being too dark.
    03-18-2016 01:53 PM
  22. AlphaVictor87's Avatar
    Don't know much about Package Disabler since I'm new to Android and Samsung, but did that help the darkness issue before? I'm just trying to figure out something in case it reverts back to being too dark.
    The update did not help the colors. I re-enabled the two Game Services, and the colors became dark again.
    Also yes Package Disable works wonders for this issue. To correct the colors you need to disable GamepadService and GameService
    03-18-2016 01:58 PM
  23. mattjewell15's Avatar
    Thanks for the quick reply. That's unfortunate, wonder why mine aren't as dark without Package Disabler.
    By disabling those two services, will that take the little features away that you can toggle off and on so that the physical buttons can't be accidentally touched while in game?
    03-18-2016 02:39 PM
  24. anon(27512)'s Avatar
    Installing it now
    03-18-2016 02:45 PM
  25. AlphaVictor87's Avatar
    No, the Game Launcher is separate from that. Ex: I still have the option turned on to block notifications will in game.
    03-18-2016 02:52 PM
33 12
  1. Replies: 4
    Last Post: 03-20-2016, 10:57 PM
  2. Data Transfer onto The Samsung Galaxy S 7 Edge
    By Guapa111 in forum Samsung Galaxy S7 edge
    Last Post: 03-19-2016, 08:18 AM
  3. Replies: 3
    Last Post: 03-18-2016, 02:29 PM
  4. Wifi and Email Problem on S7, how can I fix this?
    By acambridgegal in forum Samsung Galaxy S7
    Last Post: 03-18-2016, 12:06 PM
  5. AT&T Out With a Security Update
    By Scutley in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 12:03 PM
