1. dinoo82's Avatar
    Every time i pull down the notification bar to sync my apps, a popup tip/help would show saying
    "Turn on Auto sync
    Any changes you make to your accounts on the web will be automatically copied to your device.... and it goes on..."
    Below the message, it will then say either cancel or OK. Is there a way to disable this pop up / tip from showing up every time I click on the sync button??
    03-18-2016 03:07 PM
  2. RishuG's Avatar
    I don't think you can remove it without root. But you can automatically dismiss it within a split second with tasker and auto input plugin. I hope you're aware of tasker. It's a phone automation app. You create an event profile with %WIN variable linking to a task which dismisses the popup. That quite solves the problem. I use Sam S6 with marshmallow & faced the same problem. There is an article on a small blog (tech-rg) on blogspot too on this. Don't ask me for article link as I don't have it now and it's against the rules too. I found it in a reply of this same question on the xda forum.
    04-16-2016 05:52 PM
  3. spookymyo's Avatar
    Know of any method for those of us that do have root?
    09-22-2016 10:07 PM
  4. AaronHan's Avatar
    Hi, manage to find a fix for root users?
    10-18-2016 08:07 PM
  1. How do I get rid of the Xinyinhe adware?
    Last Post: 07-09-2016, 01:30 PM
  2. What app to use to BU data and app from old phone ?
    By billyjoebob007 in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 04:31 PM
  3. How to reset fingerprintpassword
    Last Post: 03-18-2016, 03:14 PM
  4. Replies: 0
    Last Post: 03-18-2016, 02:39 PM
  5. Replies: 0
    Last Post: 03-18-2016, 02:36 PM
