10-17-2016 04:26 PM
54 123
tools
  1. Adam Zeis's Avatar
    That would be awesome. My biggest issue is actually running my power cable across my console to the mount. It just hangs there and gets all kinds of in the way.
    03-22-2016 10:55 AM
  2. Tim1954's Avatar
    I have a QI charging pad in the centre console, I turn Bluetooth on, put the phone away and drive the car..
    03-23-2016 03:22 AM
  3. MrOnager's Avatar
    Amazon has a nice selection of styles & colors. Search "Cord management clips"
    03-25-2016 10:35 PM
  4. Jason Fournier1's Avatar
    I got this one that attaches to the air vent and has fast wireless charging built in. Qi-Infinity Fast Wireless Car Charger Dock; 1.5A (2A Max, 10 Watt) For Samsung S6 Edge/Note5 & Compatible with Qi-Enabled Devices https://www.amazon.com/dp/B018INZ10O...cUvbUpU5086843
    It works great. You do need a fast charge adapter which I already had anyway.
    03-26-2016 10:39 AM
  5. dman76's Avatar
    I got this one that attaches to the air vent and has fast wireless charging built in. Qi-Infinity Fast Wireless Car Charger Dock; 1.5A (2A Max, 10 Watt) For Samsung S6 Edge/Note5 & Compatible with Qi-Enabled Devices https://www.amazon.com/dp/B018INZ10O...cUvbUpU5089644
    So you are using it in the vent? I have never used a vent mount before. Does it hold it pretty secure?
    03-28-2016 12:45 AM
  6. flintlock's Avatar
    Now they just need to make a powered CD slot mount.
    Amen. They did it with the cassette. When I first saw it I had to check if that was there. Disappointed.
    03-28-2016 04:34 AM
  7. flintlock's Avatar
    Not the one I tried. Vents move.
    03-28-2016 04:35 AM
  8. bigslam123's Avatar
    I use the Choetech wireless charging mount. http://www.amazon.com/gp/aw/d/B00F5X...cUvbUpU5089798
    03-28-2016 04:41 AM
  9. Mike-Mike's Avatar
    i got my proclip dash mount in and put an iBolt on it, great combo
    03-28-2016 08:49 AM
  10. physicsguy's Avatar
    I second the praise for proclip, it really is secure and well made. I had an iBolt with my Note 3 prior to the S7 edge, now I have a Samsung wireless holder mounted on the proclip.
    03-28-2016 10:09 AM
  11. JimA's Avatar
    Do you have links for these, and maybe how it works together? Thanks.
    03-28-2016 10:32 AM
  12. felloffthetruck's Avatar
    Have the ProClip with ball mount and was using the iOttie Qi wireless charger but hated the cord hanging down. I changed the head to the iOttie easy one touch 3. No wireless charging though.
    03-28-2016 10:40 AM
  13. Jason Fournier1's Avatar
    Yes it holds fine. It uses a spring adjustable clip to the vent and and then there is another arm that leans on the dash. So it is not relying on the vent to hold it up, it is just an attachment point.
    03-28-2016 12:04 PM
  14. natehoy's Avatar
    I've never heard of the cd mounts before. They work well and without damaging the cd player?
    Yes. It's a narrow slot that fits into the CD slot and doesn't go anywhere near deep enough to reach the actual spinning CD, or even the bit that detects when a CD is inserted. My wife has been using one for a long time now and it works great.
    Obviously, if you hit the EJECT button on the CD drive while the phone holder is attached...
    03-28-2016 12:05 PM
  15. dman76's Avatar
    I just looked up the ProClip and that looks pretty nice. I think I want to stay away from the suction cup mounts because if they come loose, I am afraid this phone will crack. The CD mounts are nice but in one of our cars it really interferes with some buttons and the screen of the stereo so it's not the best for that car. I suppose a vent mount would be ok but this ProClip seems like it would work very well. I see the mounts they sell for the S7E but how do you guys put the iOttie or the Samsung Wireless holder like some of you mentioned? How do you attach it? Some kind of universal mount for it would be nice so my wife could use it for her iphone as well.
    03-29-2016 12:31 AM
  16. physicsguy's Avatar
    If you get the ball mount, it's pretty universal and you can attach many other cradles that snap onto a ball mount. It's sold separately from proclip, but my first cradle from proclip included it (for my original Galaxy Nexus), then I just swapped out other cradles onto the ball mount as I changed phones.
    03-29-2016 04:06 AM
  17. Mike-Mike's Avatar
    I will have to take a pic of it in the car later, but here are the links to the parts I got:
    I have a 2015 Chrysler 300c. On the dash below the vent, I have the ProClip Angled Mount:
    Chrysler 300 2015-2017 ProClip Angled Mount - ProClip USA
    that has a pic of it mounted to a car, that goes to the Chrysler specific one, but you can find whatever model car you have, quick 2 minute install for me. I used a proclip on a different car, and when I removed it, no marks were left
    so the Proclip mounts to the car, the ball mount screws into the plate of the Proclip:
    http://smile.amazon.com/iBOLT-IT-J9V...ilpage_o01_s00
    Then the back of the iBolt holder attaches to the ball mount:
    http://smile.amazon.com/iBOLT-336234...ilpage_o01_s00
    03-29-2016 10:21 AM
  18. Mike-Mike's Avatar
    Here are some pics
    03-29-2016 11:42 AM
  19. Mike-Mike's Avatar
    More
    03-29-2016 11:43 AM
  20. JimA's Avatar
    I like how that does not block the vent. I looked for my car and it almost completely blocks a vent.
    03-29-2016 11:44 AM
  21. Mike-Mike's Avatar
    Stupid sideways posts
    03-29-2016 11:44 AM
  22. mososki's Avatar
    I did not like the idea of pushing a button to lock or unlock the phone into the holder. I made my own drop in holder using thin plexiglassCar mounts-picture.jpg. I took apart a Tylt wireless charger and put the electronics behind the holder. I mounted it using a suction mount on my dash. Now I just drop the phone i and it chargers and switches to drive mode. Here's a picture.
    03-29-2016 08:15 PM
  23. mososki's Avatar
    I did not like the idea of pushing a button to lock or unlock the phone into the holder. I made my own drop in holder using thin plexiglassClick image for larger version.
ID:	222631. I took apart a Tylt wireless charger and put the electronics behind the holder. I mounted it using a suction mount on my dash. Now I just drop the phone i and it chargers and switches to drive mode. Here's a picture. (The holder is sideways in the picture)
    03-29-2016 08:16 PM
  24. felloffthetruck's Avatar
    The ProClip ball mount is a little over priced @ $29.99 but I paid it.
    03-29-2016 08:32 PM
  25. Mike-Mike's Avatar
    yeah that price is insane, i used the iBolt one from Amazon
    03-30-2016 10:33 AM
54 123
  1. Can my 32GB 12.2 Note Pro Be Safely Rooted With Folder Mount App?
    By tntom in forum Samsung Galaxy Note Pro 12.2
    Last Post: 10-02-2016, 09:32 PM
  2. Navigation Issue in "Car Mode"
    By frank1492 in forum Samsung Galaxy Note 4
    Last Post: 03-25-2016, 12:05 PM
  3. How to I stop my car's Bluetooth from auto-replying.
    Last Post: 03-17-2016, 04:56 PM
  4. Replies: 0
    Last Post: 03-17-2016, 04:25 AM
  5. How to get rid of "Car Mode" on s5.
    Last Post: 03-15-2016, 05:04 PM
