10-17-2016 04:26 PM
54 123
tools
  1. Simon_y7's Avatar
    Having tried several vent holders and find them literally unusable, I came across this:
    http://www.techmatte.com/Mount-VTMG
    I doubted that the magnet would hold, but the phone proved to be rock solid. It doesn't wobble all over the dash. The mount was very carefully, professionally packaged, and the company, believe it or not, has a 24/7 toll free support. I bought mine on eBay, but it's available on Amazon as well. I'm not associated with the manufacturer in any way, just impressed with the product.
    07-15-2016 04:57 PM
  2. Gunny Fitz's Avatar
    Got one of those and found the piece you insert into the car vent somewhat difficult to install.
    Once inside, it unfortunately did NOT remain in place as the weight of the phone either closed my vents, or it swayed left or right upon taking turns. I totally love the concept but would love something a bit more sturdy! Like something which fits inside the cigarette lighter hole and stays in there like a plug! - No clue what sort of safety issues may be involved, but you know what I mean. Thanks Simon!
    10-17-2016 03:08 PM
  3. maf113's Avatar
    This is the one I am using. Qi charging with triple coils. Works great.
    Z-Edge 3221817 Triple Coil Qi Wireless Car Charger Dock for Qi-Enabled Devices https://www.amazon.com/dp/B00ZBWAECQ...cUvbUpU5500433
    10-17-2016 04:22 PM
  4. pjwk81's Avatar
    I hard wired the official wireless charging holder into my ignition. Very handy for navigating without killing your battery.
    10-17-2016 04:26 PM
54 123
  1. Can my 32GB 12.2 Note Pro Be Safely Rooted With Folder Mount App?
    By tntom in forum Samsung Galaxy Note Pro 12.2
    Last Post: 10-02-2016, 09:32 PM
  2. Navigation Issue in "Car Mode"
    By frank1492 in forum Samsung Galaxy Note 4
    Last Post: 03-25-2016, 12:05 PM
  3. How to I stop my car's Bluetooth from auto-replying.
    Last Post: 03-17-2016, 04:56 PM
  4. Replies: 0
    Last Post: 03-17-2016, 04:25 AM
  5. How to get rid of "Car Mode" on s5.
    Last Post: 03-15-2016, 05:04 PM
