10-17-2016 04:26 PM
54 123
tools
  1. dman76's Avatar
    Which car mounts do you like for this phone? I used a good windshield mount and one that goes in the CD player slot before but neither of those are wide enough for this phone. Since this has wireless charging, maybe a wireless charging car mount might be nice. Just wondering if anyone has found any good ones.
    03-18-2016 04:44 PM
  2. mededitornj's Avatar
    I'm using the "iOttie HLCRIO132 Easy One Touch Wireless Qi Standard Car Mount Charger for Qi Enabled Devices." I bought it from Amazon.
    So far I'm loving it. I have it mounted on a stand in one of the cup holders.
    DFranch and CMYMUD like this.
    03-18-2016 04:55 PM
  3. jimbo1mcm's Avatar
    Mountek has a CD install mount with sliding sides that work well with this phone.
    03-18-2016 05:00 PM
  4. dman76's Avatar
    Does the charging keep up with it if you leave the screen on all the time?
    03-18-2016 05:26 PM
  5. dpham00's Avatar
    I have a vent mount and sometimes I use my magnetic mount
    Andy Adler likes this.
    03-18-2016 05:48 PM
  6. jbergsing's Avatar
    I use this mount with my Nexus 6p with no problems.
    Mountek nGroove Universal CD Slot Mount for Cell Phones and GPS Devices https://www.amazon.com/dp/B004G1L52Q...cUvbUpU5070617
    03-18-2016 05:55 PM
  7. physicsguy's Avatar
    I had been using a proclip dash mount for my Note 3 until I got the S7E. VERY secure, hasn't moved in years, and it's mounted in the grooves of my dash right in front of the AC vent, easy to install and very stable and unobtrusive. I bought the Samsung wireless car charger to go on the proclip mount. The ball socket on the proclip mount fit perfectly into the charger. Very excited that it fit since the mount that came with the Samsung charger is suction (and large) and I don't like using suction mounts. You can get a proclip mount custom for your vehicle and the wireless charger to put on it instead of a proclip holder, and you can buy a ball mount adapter plate from proclip as well.
    And by the way, I'm really loving the Samsung wireless charging holder. So easy to put in and get out quickly, the sides squeeze in effortlessly and there's a quick release button when you want to take it out. The charge wasn't enough to charge it at first, but it was a real slow trickling drain. Recently I've been reading the battery life threads and turned off ok google detection among other things and now with the screen on it will charge, but super slowly (better than a slow drain).
    03-18-2016 08:24 PM
  8. mededitornj's Avatar
    So far, yes. Tomorrow will be my first longer road-test, but I don't anticipate a major difference. I'm very happy with the wireless-chsrge iOttie.
    03-18-2016 10:14 PM
  9. anon(27512)'s Avatar
    http://smile.amazon.com/gp/product/B...ireless&sr=1-1
    This is my favorite. No wireless charging on it though. But if you pair it with these:
    http://smile.amazon.com/dp/B01A4ZGLZ...er+car+charger
    http://smile.amazon.com/dp/B012WF7OR...icro+usb+cable
    You will have an awesome car mount AND fast charging in your car.
    03-18-2016 10:28 PM
  10. Mirest's Avatar
    This is what I had before as well. The suction is incredibly strong and will definitely not come off in any circumstances. In fact it was so strong that I had to spend about 10 minutes just to transfer the mount to another car.
    03-18-2016 10:31 PM
  11. coreynjoey's Avatar
    I've never heard of the cd mounts before. They work well and without damaging the cd player?
    03-18-2016 11:34 PM
  12. ilordvader's Avatar
    Yes & its been out 5yrs now
    & now not much around cos noone useing CD
    all have USB in there cars
    03-19-2016 01:11 AM
  13. anon(27512)'s Avatar
    Did it leave a mark on the dash?
    03-19-2016 02:16 AM
  14. mustang8918's Avatar
    I use a windshield mount since I can't use a dash mount. My dash isn't smooth so those don't work for me. I tried a vent mount but when it's cold out and you have the heat on, it's not really good for the phone to be blowing hot air at the back of the phone. CD mounts are nice also but they force you to look down at your phone and I'd rather have my phone at eye level so that I'm not taking my eyes completely off the road. Just my experience and everyone is different.
    03-19-2016 08:06 AM
  15. sangs's Avatar
    Have this one in both our vehicles. Works seamlessly with all our phones. http://www.amazon.com/gp/product/B01...cUvbUpU5071539
    03-19-2016 08:13 AM
  16. Mirest's Avatar
    It did not since I actually put it on top of another dash accessory, but i heard from some reviews that it might damage certain materials. I would recommend either using it on the glass or with another platform on top of your dahsboard.
    03-19-2016 02:30 PM
  17. Mike-Mike's Avatar
    Much like physicsguy, I am getting a proclip mount. I had one on an older car and it was great.
    I also ordered the iBolt holder:
    iBOLT xProDock holder https://www.amazon.com/dp/B00KAJOSZO...cUvbUpU5072216
    03-19-2016 03:41 PM
  18. ilordvader's Avatar
    Any Fast Charge ones ?
    03-20-2016 12:03 PM
  19. dman76's Avatar
    I am just thinking in your car you might leave the screen on a lot for navigation so if you do so, is it bad to be on a wireless charger? Does that cause it to overheat or does wireless charging keep up with the battery drain from the screen always on?
    03-20-2016 01:54 PM
  20. mededitornj's Avatar
    I just got back from a 2-hour trip. Phone was at 88% when I started. Put phone in iOttie Qi wireless car charger and had Waze going. Got home and phone was still at 88% with no heat. I'm happy with that result and love not having to keep plugging/unplugging the usb.
    03-20-2016 02:09 PM
  21. dman76's Avatar
    Thanks for the info. I kind of want to mount it to the windshield just because of some of the reviews I read about it damaging the dashboard. Do you have it on the dash? If so, did you get that extra pad to mount on the dash first?
    03-20-2016 04:52 PM
  22. mededitornj's Avatar
    I actually have it mounted in one of my cup-holders. I bought a gadget that locks into the cup-holder and has a round flat top for holding suction on the charger. It's working great for me.
    I'm driving a 2012 Toyota Highlander and there just isn't a good spot on the dash to mount the charger. I got a ticket for a windshield mount (obstruction of view), so I won't go that route again.
    03-20-2016 06:39 PM
  23. mngdew's Avatar
    03-20-2016 10:11 PM
  24. Adam Zeis's Avatar
    Mountek nGroove Universal CD Slot Mount for Cell Phones and GPS Devices https://www.amazon.com/dp/B004G1L52Q...cUvbUpU5077452
    +1 for this mount. It did interfere with my radio power button a bit, but I fixed it up so it's solid now. Definitely beats a windshield or dash mount.
    jbergsing likes this.
    03-22-2016 10:34 AM
  25. dman76's Avatar
    Now they just need to make a powered CD slot mount.
    tstolz likes this.
    03-22-2016 10:51 AM
54 123
  1. Can my 32GB 12.2 Note Pro Be Safely Rooted With Folder Mount App?
    By tntom in forum Samsung Galaxy Note Pro 12.2
    Last Post: 10-02-2016, 09:32 PM
  2. Navigation Issue in "Car Mode"
    By frank1492 in forum Samsung Galaxy Note 4
    Last Post: 03-25-2016, 12:05 PM
  3. How to I stop my car's Bluetooth from auto-replying.
    Last Post: 03-17-2016, 04:56 PM
  4. Replies: 0
    Last Post: 03-17-2016, 04:25 AM
  5. How to get rid of "Car Mode" on s5.
    Last Post: 03-15-2016, 05:04 PM
