1. AC Question's Avatar
    Is there any way I can change the text vibration pattern or intensity using the Samsung messaging app with the Galaxy 7? The stock two quick buzz can barely be felt in my pocket.
    03-18-2016 05:00 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge forum.
    03-18-2016 10:22 PM
  3. bsteppuhn's Avatar
    Yes settings sounds and vibrations
    03-18-2016 10:31 PM
  4. physicsguy's Avatar
    On a similar note, I can't seem to find a way to differentiate the vibration pattern for emails from different accounts vs text messages etc.
    On my note 3 I was able to set a different vibration pattern for my different email accounts and texts so in my pocket or on a table, based on the vibration, I knew what the notification was. Was this feature removed? They all seem to just have vibration on or off.
    03-19-2016 04:32 AM
  5. jpdaballa's Avatar
    I use textra for SMS and it allows me to make custom vibrations for my received texts
    03-19-2016 06:43 AM
  1. Read Your Whatsapp Messages Without Changing Your Last Seen Time.
    By Venkatramanan Ramasubramanian in forum General Help and How To
    Last Post: 09-25-2017, 11:08 AM
  2. Replies: 1
    Last Post: 03-18-2016, 10:33 PM
  3. Dropped my galaxy s6 and it wont turn on.
    Last Post: 03-18-2016, 05:00 PM
  4. S7 Edge - Easy Tweak For More Screen Space
    By Almeuit in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 04:20 PM
  5. S7 - Easy Tweak For More Screen Space
    Last Post: 03-18-2016, 03:25 PM
