1. pstellato73's Avatar
    So my wife is switching from a 64gb galaxy s6 edge to a 32gb S7 edge. What's the best way to transfer all the data. She is filled to capacity on the 64gb phone. Is there a way to use the SD card when transferring data from the s6 to the S7?
    03-18-2016 06:17 PM
  2. anon(238680)'s Avatar
    No. I can't really believe anyone could fill up a 64gb phone. Anyhow, you can't transfer directly to the SD card unless you use a PC, then it would only be music, photos, etc. There's quite a bit of discussion on the board on this topic.
    03-18-2016 06:44 PM
  3. brava27's Avatar
    Tons of videos and mp3s can do it. I had 64gb and my commute was never boring because I had lots of content lol
    03-18-2016 06:51 PM
  4. dpham00's Avatar
    You can use the usb otg adapter to connect the old device then copy over media using the my files app
    03-19-2016 07:53 AM
  5. sangs's Avatar
    Are you kidding? I currently have nearly 100 GB of music, photos and video on my microSD card. It's very easy to fill.
    03-19-2016 08:17 AM
  6. anon(238680)'s Avatar
    Will that copy files directly to the SD card? Regardless, you can't copy apps directly to the SD which is what i thought the OP was referring to. In part at least.
    03-19-2016 11:16 AM
  7. dpham00's Avatar
    You should be able to using the my files app . files at least. Not apps
    03-19-2016 12:43 PM
  8. t11rmh's Avatar
    Quite easily done with HD videos and Hi-Res audio, mp3's, et al. You can never have too much space.
    My 128gb card has about 9gb free.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    03-19-2016 02:18 PM
  9. rkkeller's Avatar
    I would copy all the pics, music and video to a computer, then to the sd card. For the apps and other things, you can use Samsung Sync to copy phone to phone.
    03-20-2016 07:44 AM
  1. samsung mail app causes emails to be marked as read in other clients
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 01-08-2017, 04:10 PM
  2. Soon you can book your OLA cab from Google Map itself
    By Venkatramanan Ramasubramanian in forum General News & Discussion
    Last Post: 03-18-2016, 10:32 PM
  3. Replies: 1
    Last Post: 03-18-2016, 10:29 PM
  4. Replies: 3
    Last Post: 03-18-2016, 08:56 PM
  5. Windows Phone User Looking to Android
    By WILLIAM SHEA in forum Ask a Question
    Last Post: 03-18-2016, 04:50 PM
