1. Seremedy's Avatar
    Does anyone use this ? It completely debloats your phone. Does it speed it up or drain any battery ?
    03-18-2016 06:28 PM
  2. dpham00's Avatar
    I haven't noticed much difference on mine
    03-18-2016 07:08 PM
  3. rong21's Avatar
    I've never noticed any difference in performance disabling bloat on any phone I've owned.
    03-18-2016 07:20 PM
  4. Rheller82's Avatar
    Its great for disabling the game enhancer service, but mostly it's for hiding the crap software and it does that well.
    dizzll likes this.
    03-18-2016 07:30 PM
  5. meyerweb#CB's Avatar
    Does it actually remove apps, or just "freeze" them? And will it disable apps that can't be disabled using the built-in App Manager?
    Finally, any impact on the Knox e-fuse if you remove / disable apps using this tool?
    03-18-2016 08:18 PM
  6. dpham00's Avatar
    Without root it just disables them. You can disable apps that cannot be disabled in the app manager without root. I haven't heard of it tripping the Knox fuse on any device.
    03-18-2016 10:35 PM
  7. dizzll's Avatar
    I don't notice any performance advantage but it makes me happy the icons disappear lol
    Rheller82 likes this.
    03-18-2016 11:14 PM
  8. wxman2003's Avatar
    It's a waste of time and money. You may save 10 minutes of battery life a day using it.
    03-18-2016 11:19 PM
  9. ajp8806's Avatar
    While that may be true, I use it to get rid of some of the icons, seeing as we can no longer hide them.
    03-18-2016 11:53 PM
  10. meyerweb#CB's Avatar
    Thanks guys. I'm using Nova, and it lets me hide app icons, so I probably won't worry about Package Disabler for now.
    eewwyeah likes this.
    03-19-2016 03:37 PM
  1. How to disable sync notification pop up
    By dinoo82 in forum Samsung Galaxy S7 edge
    Last Post: 10-18-2016, 08:07 PM
  2. Oukitel K6000 Pro - Monday through Friday battery life!
    By worldspy99 in forum Rumored Devices Lounge
    Last Post: 03-29-2016, 02:20 PM
  3. Replies: 0
    Last Post: 03-18-2016, 02:36 PM
  4. How to disable email message from keyboard?
    Last Post: 03-18-2016, 04:15 AM
  5. Disable Application Notification Menu
    Last Post: 03-18-2016, 12:15 AM
