Do you use always on display?
t11rmh
637
I use it with the calendar setting. As I have my phone in a belt case when I am carrying it it is only on when I charge it up over night so it doesn't drain my battery.
Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
paridge
274
Love it! Nice to be able to see the time and date without waking up the phone. I also like the “keep screen off” feature that turns the screen off when the phone is in my pocketbook.
hasasimo
961
Absolutely. Been hooked on the convenience of both always-on displays and wireless charging since my Nokia Lumias in 2012. Good to see the technology on some Android flagships as well.
Truman82
109
I heard that always on display saves battery if you use clock widget as you don't have to light up the phone all the time to see the time?
farhanmohd
92
That's more than enough if it shows calls and messages. In the end the idea is that you do not miss your primary notifications i.e. calls and messages.
dov1978
Trusted Member
Oct 22, 2012
1,749
Use it always. Missed this feature so much from Nokia/Microsoft Lumia's. Just such a shame it only shows notifications for calls and sms for now. Sooo hoping they update it for 3rd party apps soon
Rumblee1
Trusted Member
Nov 3, 2012
1,521
3
38
15%? Don't see how thats possible. Its purpose is to save battery. When you check the time or to see if you have messages, you won't be lighting up all that screen real estate. I've been using it since I received my S7 Thursday and getting tremendous battery life.
dov1978
Trusted Member
Oct 22, 2012
1,749
Too much for me, with it on it drained over 15% at night consistently. Off it only drains around 6%
Sounds about right. 15 - 6 = 9% drain more than usual overnight with it turned on. Most people charge their phone overnight so there would be no drain and they'd save during the day not having to constantly wake the phone
Cobravision
1,271
40
48
I turned it off because I didn't want it on while I was sleeping. If there's a way to have it disable during certain times, I'd turn it back on. I liked how you knew which way was up instantly.
TechGod2014
484
I used it once and it used more than 1% battery life per hour. Seems like a waste of battery life for me since I'm not getting the battery life others are claiming and I can just simply swipe on the edge while it's off and see the notifications the same way. I would know that there's a notification with the LED blinking.
Jason Fournier1
203
You can enable the edge to be on instead during certain times, which is what I did. Less light from that.
KPMcClave
1,777
That would be the Night Clock, in this case. Settings > Display and wallpaper > scroll to Night Clock and toggle it on.
This overrides the Always On screen and displays the time and your next alarm along the edge. You're able to set the time for start and end, and whether the clock displays on the right or left edge of the phone.
KPMcClave
1,777
I had it on, turned it off, and now have it back on again.
I had this sort of feature on my Motorola Maxx and Turbo phones and loved it. This isn't quite as useful as Moto's version, but it's OK.
The problem for me is that if I do turn it off, there doesn't seem to be another way to use the S7E as a bedside clock. The Night Clock feature I just mentioned above is too small, and if I disable Always On, there isn't a Clock option in Daydream. I'd have to install a third party clock app to get a bedside clock displayed.
Have I missed something?
Akshay
