Tmobile security update battery drain?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
Don't bother. My Nexus 6 started to drain battery frequently after the security update. After 4 hours it goes down 6% with not even touching it. Before it only went down 1 or 2%. I must have ran about 10 cache wipes since. Does nothing.
That's helpful to know, thanks. Still, different people may have somewhat different root causes, and since a cache partition wipe doesn't hurt, it's probably still worth trying at least once.
p213crew
I am also having same battery issue. Before update my battery would last all day. I would get home and I would be at 75%.
I only text and do some occasional email. No facebook. No Instagram, No Snapchat. I uninstalled Facebook for good measure. Disabled all apps I am not using. Installed a dark theme. Went into Developer mode and set setting to only have 3 apps in background running ( I think that's what it is called). BAttery was awesome until update. I double checked my settings after the update and they are still set but battery is bad now.
Doing the Cache PArtition wipe now. Will see if that helps.
I am on AT&T. My sister who is on T-Mobile also noticed battery drain faster after update.
P213crew
Nikkiekoala
93
Because the update took a toll on my battery tmobile exchanged my phone and now I am a very happy camper BUT now I am getting the message and nag screen to do the update. NO Way am I going to do that so is there a way to stop the nag screen and to get it out of my notifications?
optimummind
304
Long press the notification & turn off the notification option, if you're able.
I had a similar experience after receiving the update on my Sprint GS7E. A soft factory reset didn't do anything. After 2 hard factory resets, my battery life became better.
