1. victor santos3's Avatar
    When scrolling left and right everything seems normal and smooth,but try to scroll a little bit or halfway then stop but keep your finger on the screen,you will notice the apps and widget start to shake or wiggle even though your not moving your finger, have you guys experience this issue?
    03-20-2016 12:11 AM
  2. clborden's Avatar
    Not really. If anything, my finger might be making it "shake" a tiny bit. Definitely nothing to write home about.
    03-20-2016 01:21 AM
  3. Kristian Nikolov's Avatar
    I have the exact same issue, it's like the touchscreen is way to sensitive and cannot locate the exact area where the finger is. I also have a lot of ghost touches and a lot of times the screen registers a touch when my finger is about 2-3 mm away from it.
    03-20-2016 01:33 AM
  4. victor santos3's Avatar
    So you did experience the same issue.
    03-20-2016 05:44 AM
  5. victor santos3's Avatar
    right.or a bug in the sofware,i even remove my zagg screen protector thinking it might be causing the issue but nope it's still there,i even tried it on my old smartphones Gs3 & Lg G3 and they dont have the same issue,im gonna try the s7 edge devices @ at&t and bestbuy store and see if they have the same issue,if they do im keeping my device if they dont im exchanging it,my 14 day return window is up today,are you planning on exchanging or returning your device?
    03-20-2016 06:09 AM
  1. Galaxy s7 screen dimming???
    By AC Question in forum Samsung Galaxy S7
    Last Post: 08-31-2018, 06:49 AM
  2. camera failure on Galaxy S7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-20-2016, 06:23 AM
  3. Samsung Galaxy S7 Space bar
    Last Post: 03-20-2016, 01:46 AM
  4. Issues turning on Samsung Galaxy tab 2
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 03-20-2016, 01:17 AM
  5. Galaxy s7 edge charging slow
    Last Post: 03-19-2016, 10:47 PM
