If you google there are widespread reports of the clear view case scratching the S6 screen, the consensus seems to be sand/grit/dust trapped under the flap and sand especially is apparently harder than GG4. It is a strange one as I have never heard of this before on a phone.
I'm curious if the S7 has the same issue?
