1. Robb Matherly's Avatar
    Title says it all. I have wiped the cache, tried it in airplane mode, plugged in/on battery, everything. Almost always around the 90 k mark. Is my phone defective somehow?
    03-20-2016 06:51 AM
  2. brava27's Avatar
    No. Antutu is stupid. Don't bother with that stuff. Just use your phone as you normally should.
    bhatech and Jason Stroud1 like this.
    03-20-2016 07:06 AM
  3. Robb Matherly's Avatar
    You don't think some hardware might be defective? Everyone seems to hit in the 135k range yet mine is struggling to hit 90k. I was wondering if there was a way to see if it is throttling or something.
    03-20-2016 07:15 AM
  4. brava27's Avatar
    I am gonna do an antutu right now see what I get....
    03-20-2016 07:16 AM
  5. brava27's Avatar
    03-20-2016 07:24 AM
  6. MartinMPL's Avatar
    Well I got 128K first time test (they are normally faster second time for some reason...) But honestly I wouldn't be bothered, as long as everything works OK in the real world...
    03-20-2016 07:24 AM
  7. Gator352's Avatar
    This is a synthetic test. Apps you have installed, settings you have set, and processes in the background will contribute to the outcome. Mostly to the negative.
    The best way to run it is on a clean phone. No apps, everything turned off, and no background processes running. So to get the best score, reset your phone, turn everything off, and rerun the benchmark.
    bhatech likes this.
    03-20-2016 07:39 AM
  8. Robb Matherly's Avatar
    03-20-2016 07:44 AM
  9. tripleblaze's Avatar
    My s7 edge scored a total of 133202 and the biggest difference compared to your individual scores is that mine scored 56,596 on the 3D test (ux scored 39808 and cpu scored 30,711). Do you have power saving settings turned on in game launcher? If so, I wonder if that might be causing it to throttle down performance in this test.
    03-20-2016 08:24 AM
  10. Robb Matherly's Avatar
    Nope. No power saving anything turned on. No power saving apps at all. Hell not a whole lot of apps.
    03-20-2016 08:27 AM
  11. Robb Matherly's Avatar
    On a lighter note the 4g radio is just fine.
    Help!  My new Verizon Edge can not hit above 87K in Antutu.-screenshot_20160320-092255.jpg
    03-20-2016 08:28 AM
  12. bsteppuhn's Avatar
    I hit 120s but I have bare minimal on mine. I'm also under wifi that could be a difference
    03-20-2016 11:18 AM
  13. sfla99's Avatar
    I notice looking at the scores you have two different models links, perhaps one 820 and the other is exynos?
    03-20-2016 12:25 PM
  14. wxman2003's Avatar
    My test result. Verizon S7 Edge.
    Help!  My new Verizon Edge can not hit above 87K in Antutu.-screenshot_20160320-130511.jpg
    03-20-2016 01:07 PM
  15. t11rmh's Avatar
    This is my result. It is an unlocked phone in the UK so doesn't suffer the bloatware of US models.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    Attached Thumbnails Help!  My new Verizon Edge can not hit above 87K in Antutu.-7384.jpg
    03-20-2016 03:01 PM
  16. Seremedy's Avatar
    Put your phine in the freezer for like 5 minutes lol. Seriously though, I ts heat that determines your score, my 6P on geekbench ranges from 4000 to 5300 !! Which is nearly the same as the s7e but the snapdragon 810 is a heat machine and it being idle is in the 80-90s compared to the edge at like 70-80 and hasnt ever hit 100 degress F. 6p hit 120 before...
    03-20-2016 05:51 PM
  17. jdfry15's Avatar
    My tmobile unit is always around 120k to 123k and never that low.
    03-20-2016 05:55 PM
  18. badMojo69's Avatar
    LOL really...sure call the phone defective and send it back. I'd really like to know what they say when you tell them the reason.
    03-20-2016 06:43 PM
  1. Replies: 5
    Last Post: 10-17-2016, 03:31 PM
  2. Can't update past 5.0
    By Mike d82 in forum Samsung Galaxy S5
    Last Post: 03-20-2016, 12:24 PM
  3. My samsung Galaxy s4 says 'unfortunately
    Last Post: 03-20-2016, 07:11 AM
  4. How do I update my credit card information?
    Last Post: 03-20-2016, 07:10 AM
  5. Replies: 1
    Last Post: 03-20-2016, 07:08 AM
