1. melmc1403's Avatar
    Hey!
    Still debating whether to upgrade to the S7 Edge from my note 4. Is it worthy of upgrading to?
    Thanks
    Posted from My Note 4
    03-20-2016 07:57 AM
  2. brava27's Avatar
    Hey!
    Thanks
    That's your decision. Read the specs and see if you can afford it.
    03-20-2016 08:15 AM
  3. limitbreak09's Avatar
    If Note 5 to S7e not so much. But coming from Note 4? Definitely worth it
    -S7Edge
    03-20-2016 08:45 AM
  4. dpham00's Avatar
    I would say so.
    03-20-2016 10:01 AM
  5. t11rmh's Avatar
    Hey!
    Thanks
    I upgraded from a Note 4 to the S7 edge and don't regret it one bit. Unless you use the s pen it is a worthy upgrade.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    03-20-2016 11:03 AM
  6. tsells's Avatar
    You might want to check this thread out: http://forums.androidcentral.com/sam...-note-4-a.html
    03-20-2016 11:09 AM
  7. PortablePete's Avatar
    I'm waiting for the note 6. My pen is just too handy for me. The s7 is a great phone but I'm note centric. I have hundreds of quick diagrams and lists in my phone.
    03-20-2016 11:38 AM
  8. andrew_ackley's Avatar
    Hey!
    Thanks
    I'd do it I'd you don't use the s pen much. So much more pocket able and easier to hold.
    03-20-2016 11:51 AM
  1. How to fix Kyocera Hydro bootloop after firmware update
    By FenMoonsong in forum Ask a Question
    Last Post: 04-02-2016, 10:58 AM
  2. Help! My new Verizon Edge can not hit above 87K in Antutu.
    By Robb Matherly in forum Samsung Galaxy S7 edge
    Last Post: 03-20-2016, 07:43 PM
  3. Replies: 1
    Last Post: 03-20-2016, 08:08 AM
  4. Samsung Galaxy S7 Edge Issues
    By YoungASC in forum Samsung Galaxy S7 edge
    Last Post: 03-20-2016, 07:09 AM
  5. How to uninstall zawgyi unicode fornt build in samsung s5
    By yan paing1 in forum Ask a Question
    Last Post: 03-20-2016, 06:00 AM
