Cpu Temps were in the 70s and low 80s degrees C. I was downloading from Google Drive with an average of about 50 mbps, somewhere around 20gb or so. Luckily it wasn't in the middle of the night where my mobile data speeds have exceeded 100 mbps... It probably would have restarted the phone. I typically see restarts when cpu Temps go into the 90s degrees C.
I was getting the cooling down message that I have posted about before.
It shows 40 degrees C in the cpu-z app? That's about the lowest I see when it is not doing anything.80 degrees celcius ??? Wow my s7e doesnt go past 40 degrees c or around 90 or so Fahrenheit ever. Your cpu obviously inderclocked itself because of the heat
That's cpu Temps... The outside of the phone is pretty warm but still much cooler than that.I'm amazed you haven't burned your hands. That a temperature range from 170 to near 200 degrees F!
