1. dpham00's Avatar
    Snapdragon 820 only seeing 1.2ghz at full load?-uploadfromtaptalk1458484208129.jpg
    03-20-2016 10:30 AM
  2. Gator352's Avatar
    Wow. I wonder if they lied and is still throttling?
    03-20-2016 10:47 AM
  3. makaroni's Avatar
    Is that a screenshot of an app or program that shows you what processor your phone is running and the speed? I read that some S7 edge phones were made with an Exynos 8890 and some were made with the snapdragon 820. That could be the reason for the slower speeds. I'm learning more about these phones and don't know it all so thats why I'm asking questions. Is there a way to see which processor is in your phone? Is it on the box or can I find it in settings?
    03-20-2016 10:56 AM
  4. mavrrick's Avatar
    That screen shot is of cpu-z and is the Qualcomm variant with the SD820. What were the Temps of the phone. Was it hot or something from wireless charging or something else.
    There is a thermal tab in that same app that may shed some light on how hot the SOC is. May be good to provide that as well.
    03-20-2016 11:03 AM
  5. dpham00's Avatar
    Cpu Temps were in the 70s and low 80s degrees C. I was downloading from Google Drive with an average of about 50 mbps, somewhere around 20gb or so. Luckily it wasn't in the middle of the night where my mobile data speeds have exceeded 100 mbps... It probably would have restarted the phone. I typically see restarts when cpu Temps go into the 90s degrees C.
    I was getting the cooling down message that I have posted about before.
    03-20-2016 12:04 PM
  6. Seremedy's Avatar
    80 degrees celcius ??? Wow my s7e doesnt go past 40 degrees c or around 90 or so Fahrenheit ever. Your cpu obviously inderclocked itself because of the heat
    03-20-2016 10:38 PM
  7. mavrrick's Avatar
    Yep. That has to be thermal throttling then. Thanks for clarifying that since now it makes sense.
    03-21-2016 12:09 AM
  8. Seremedy's Avatar
    Np. Wierd, this is the only phone ive had zero thermal throttling with, except when it was 100 degrees outside and my s7e hit like 98 degrees it underclocked a little bit. But samsung did a good job with the heat pipe
    03-21-2016 01:40 AM
  9. wxman2003's Avatar
    I'm amazed you haven't burned your hands. That a temperature range from 170 to near 200 degrees F!
    03-21-2016 01:52 AM
  10. dpham00's Avatar
    It shows 40 degrees C in the cpu-z app? That's about the lowest I see when it is not doing anything.
    03-21-2016 07:50 AM
  11. dpham00's Avatar
    That's cpu Temps... The outside of the phone is pretty warm but still much cooler than that.
    03-21-2016 07:51 AM
  12. Darkmatter0603's Avatar
    Do you guys know what the maximum temperature would be for the Snapdragon 820, before it gets damaged?
    04-05-2016 11:25 PM
  1. Unlocked AT&T Samsung S5 phone 4 sale
    By cardboard60 in forum Marketplace Archive
    Last Post: 04-05-2016, 07:05 AM
  2. Does moving apps to sd card on galexy s7 edge only move apk
    Last Post: 03-21-2016, 06:09 PM
  3. Replies: 1
    Last Post: 03-21-2016, 06:21 AM
  4. Launcher loading problem
    Last Post: 03-20-2016, 02:37 AM
