1. sfla99's Avatar
    Hi all,
    So last night I got a text message from att -
    AT&T FREE Message, this is an automated message please ignore.
    With a random code each time, I have no joke 25 of these since yesterday, any one know what's up? I called att and they were like we will make a ticket and get back to you.
    Uhhg lol
    03-20-2016 10:36 AM
  2. dpham00's Avatar
    You can temporarily block all text messages if they annoy you too much.
    03-20-2016 10:41 AM
  3. stra10's Avatar
    Same.
    I just upgraded to the S7 and have been getting 20+ messages a day since Wednesday. It's really annoying. I've not blocked the number because I want to figure out why they are being sent.
    Other threads say it's either:
    • AT&T Messages (App) needs disabled
    • Need to disable Messages Backup & Sync feature on the line
    But I don't have that App on my phone or that Feature on my line. Quite annoying but determined to figure out why.
    03-20-2016 02:51 PM
  4. stra10's Avatar
    So I just looked up the AT&T Messages App and it appears it is not compatible on the S7 but the Play store thinks it is installed: <UGH I CAN'T Post Links. Just search the Play Store for "AT&T Messages">
    So I tried logging into the webapp go to 'messages.att.net'
    Durning the log-in/setup process I got a text from that annoying number. See attached:
    AT&amp;T automated message spam, need some help!-screenshot_20160320-125930.jpg
    I don't see anyway on how to configure the App from the web but I'll keep looking.
    03-20-2016 03:03 PM
  5. rkkeller's Avatar
    I have ATT too and do not receive these. I also do not have them blocked.
    03-21-2016 01:51 PM
  6. rkkeller's Avatar
    The messages backup and sync is automatically installed and found under the Messages/More/Settings.
    Mine is off.
    03-21-2016 01:53 PM
  7. Adiliyo's Avatar
    i don't think i've gotten anything from AT&T aside from confirmations of my bill being paid or order confirmations.
    also Customer Service surveys after i do something at a store.
    03-21-2016 04:56 PM
  8. pgood4's Avatar
    I was getting these every few hours and finally just blocked the number. I hadn't called at&t since I wasn't sure I was staying with the phone, but will likely talk to them now and see if they can't turn it off.
    03-22-2016 08:35 AM
  9. munnarg's Avatar
    I have an ongoing case with At&t about these messages. I sent them a dump log last night as well per Samsung's request, so we'll see what they come up with. I blacklisted the number in Textra, but since Friday (when i got the phone) I'm well over 300 messages so far.
    03-22-2016 09:41 AM
  10. pounder001's Avatar
    I am w/AT&T and so glad I don't get these messages - GL to those who do in getting this resolved quickly!
    03-22-2016 04:25 PM
  11. Voldi Way's Avatar
    Ever since I upgraded my phone to a Samsung Galaxy S7, I've gotten hundreds of those same messages too. They all say "AT&T FREE MESSAGE - This is an automated message, please ignore." followed by a random code. It's super annoying.
    I finally resorted to blocking that number in order to make it stop. Please let me know if you figure out a more elegant solution.
    03-23-2016 02:18 PM
  12. Scutley's Avatar
    Hi all,
    Uhhg lol
    What?
    03-23-2016 03:59 PM
  13. Scutley's Avatar
    Reset the phone to it's factory settings or default might help.
    I would do the reset setting to it's default first.
    Go to:
    Settings-Personal-Backup and reset-Reset settings
    or if you really want to erase everything on your phone you can do a factory data reset.
    Go to:
    Settings-Personal-Backup and reset-Factory data reset
    03-23-2016 04:06 PM
  14. sfla99's Avatar
    So far no resolution, tier 2 reps have no idea as they say I should make changes too att messages however it's not on my phone nor any att edge I have tested in store.
    Went to retail store they gave me a new sim and again no luck, they are saying incised try a factory reset but what is that going to do, these messages are coming from their servers, my device has nothing to do with them sending me sms.
    They were like we'll you can block them as a resolution. I said no that's not a proper fix as that stops the annoyance but not the issue. Grrrrr.
    03-25-2016 12:20 AM
  15. sfla99's Avatar
    Think I solved the issue, I re enabled HD voice and the text messages have stopped, this assumes these messages are part of the new enhanced Lte services they are trying to push.
    The scary issue is, what are they doing pinging me randomly through some sms service.
    03-25-2016 10:46 AM
  16. infinitodd's Avatar
    So when I upgraded my phone to a Galaxy S7 Edge, I went straight to my third party sms app to handle messages. Didn't even activate the stock "message" app that came with the phone. Couldn't get these messages to stop. I even went through the AT&T facebook messenger to speak to a representative over the course of several days. They couldn't help. Frustrated I remembered some old tech logic I once knew, nothing fancy, just the fact that the 3rd part app lays on top of the stock app and utilizes it (somewhat) to manage messages through its own interface. I activated the stock message app, made it the default. I blocked the number through that app (both for calls and messages) then made the third party app the default again. I used to get that message every fifty-two minutes on average. Been over two hours and no more "AT&T free message" messages.
    Hope this helps.
    04-05-2016 10:27 PM
  1. Snapdragon 820 only seeing 1.2ghz at full load?
    By dpham00 in forum Samsung Galaxy S7 edge
    Last Post: 04-05-2016, 10:25 PM
  2. Unlocked AT&T Samsung S5 phone 4 sale
    By cardboard60 in forum Marketplace Archive
    Last Post: 04-05-2016, 06:05 AM
  3. How to print email message?
    Last Post: 03-20-2016, 10:07 AM
  4. I need a small one handed use phone!
    By morpho4444 in forum Ask a Question
    Last Post: 03-20-2016, 09:19 AM
