Is it just me or does the Samsung keyboard work really well these days
bsteppuhn
831
The only thing that chaps my bottom is the predictor on the swipe is BS. I sound like a raging alcoholic if I don't browse over it before I send it.
Posted from the S7E Chrome™ on Big Red
Is this when it changed your words when a ? Or ! Is used
ApprenticeSecond72
I personally really enjoy the keyboard, aside from a few of it's minor quirks. Like how the speech-to-text button it right next to the comma and I'll accidentally hit it when going for the comma and have to exit out of that screen after the little double beep. Or how i can't set a default for that button, as it contains speech-to-text, emojis, drawing-to-text, clipboard, keyboard options, and a keyboard size toggle. Or, and this one is my favorite, I'll try to add a question mark to the end of a question and the keyboard will decide to freeze. But, other than these minor, frequent hiccups, I find myself rather enjoying this stock keyboard, especially the swype feature.
Adiliyo
2,412
49
it's gotten significantly better, personally i use chrooma keyboard because i like how it changes color based on the app.
the small things in life.
also, i like the google style of where the ! and ? are (long press on . and swipe over) i've gotten too used to that and find samsung's to be less efficient.
aximmaxim
8
I've been using Samsung keyboard, although I own Swiftkey. Prefer the layout on swiftkey slightly, but why add the additional program when you can't uninstall the samsung app anyway?
Iva_LadyDiCaprio98
785
I got my s7 edge yesterday and the keyboard is amazing so easy to type on and rarely any typos - I kept making a lot of typos on the s5. Samsung did a great job with this phone. I am so happy with it.
makaroni
1,209
When I first took my phone out of the box, I used the Samsung keyboard and it was performing well. The response was great and the predictions were somewhat on pint too for it not learning how I type yet. However I'm so used to the placement of the punctuation marks and other options on SwiftKey that I had to apply it again. Muscle memory has me where I don't want to learn another keyboard. It worked well though
Liskrig
Active member
Mar 8, 2012
42
I used it for the entire setup process at the T-Mobile store, and it was nice. My stress-test for any keyboard is to just mash the keys like a monkey and see how well it can figure out what I'm trying to say, and as far as stock keyboards, this one worked very well! I soon after installed Swiftkey due to some themes I liked, and the fact that I've used it since v3.
torbach1
1,008
It does work pretty well although it really wants me to email someone. Ended up switching to swiftkey.
That's exactly what I've experienced. It seems to constantly predict my next word as a particular friend of mine's email address, even though I haven't emailed him in over a year. Maybe it's trying to tell me something, but it gets annoying. Switched back to Google Keyboard.
I used to be a die-hard Swiftkey fan, but I found that it slowed down so significantly over time, that I gave up. Perhaps I was pointing it to too many personal sites to learn from?
Not Quite Right
Trusted Member
May 6, 2013
232
This seems to be the same keyboard as the Note 5's, if so then ya its a keeper. I never did get around to loading Swiftkey because I found no need ...
aggie
916
32
28
First Samsung device I haven't immediately replaced the keyboard on . I'm sticking with the stock one for now.
Mike-Mike
1,628
I believe there is a setting to address that. however I cant find it at the minute. My brain seems to think there was a checkbox somewhere that offered to suggest contacts when typing
torbach1
1,008
Thanks! I'll see if I can find that.
say anything
56
I used to use SwiftKey religiously, but I haven't switched from stock yet. SK has gotten increasingly worse at corrections and predictions in the last year or so and this Samsung keyboard has been working just fine.
Chen 2
3
shhh.... it's blasphemy to say that you like stock stuff on Android forums!
srsly though, I use the stock keyboard for my samsung phone and my iPad. The stock samsung keyboard is not as good as the stock Apple keyboard but you know what, third-party keyboards suck. If they type well they look like crap and if they look good, they don't work all that well. Stock is the best compromise between the two. Swiftkey definitely does a great job at auto correction, but it just looks really cheap and stupid.
And no, having skin support is not the same thing as looking good. looking good means you have actual talented visual designers making a design that fits well with most of the apps you'll be typing in. Stuffing a a keyboard with Iron Man colors and images is not "good".
