1. Proman28's Avatar
    Hi
    I just received my S7 edge and want to know is it unlocked to any network or whatever sim you use first time it will locked on it?
    I just want to make sure because next month I am planning to go abroad and will use their local sim card.
    How can I set my Micro SD card to store all my images and audios whatever I download or received from WhatsApp or Viber or Tango. Donot want to save on mobile's hard drive.
    Thanks in advance
    03-20-2016 02:53 PM
  2. itguyjax8430's Avatar
    Hi
    Thanks in advance
    Welcome to Android Central!
    Where are you located and where did you buy the S7 from?
    03-23-2016 06:37 AM
  3. flintlock's Avatar
    Re your saving settings look in the individual app's settings for save locations. Set them to your external. I don't use those particular apps but that's usually how it is.
    I can't comment on the other. Being on Verizon that's long been a downside.
    03-23-2016 08:07 AM
  4. Proman28's Avatar
    HI
    I am in UK and bought it from Samsung Online.
    03-31-2016 06:23 AM
  1. Replies: 43
    Last Post: 03-23-2016, 02:38 PM
  2. Where is my clipboard on my Samsung A3?
    By AC Question in forum Samsung Galaxy A3
    Last Post: 03-23-2016, 01:18 PM
  3. please help how to downgrade note4 with bootloader coj5?
    By ahmed saad5 in forum Samsung Galaxy Note 4
    Last Post: 03-20-2016, 03:26 PM
  4. Why is my Auto Rotate not working on my HTC One M9?
    Last Post: 03-20-2016, 03:07 PM
  5. Replies: 1
    Last Post: 03-20-2016, 02:35 PM
