1. AC Question's Avatar
    For those of you who have the S7 Edge, how well is the camera? Does it do well with zoom?
    03-21-2016 08:58 AM
  2. Sohail Kazi's Avatar
    It is great u can also record in 4k
    03-21-2016 09:12 AM
  3. dpham00's Avatar
    It is great, best that I have used. But zoom is still digital so...
    srkmagnus likes this.
    03-21-2016 05:34 PM
  4. srkmagnus's Avatar
    Take a look at the AC review and sample pics here: http://www.androidcentral.com/samsun...s7-edge-review
    03-21-2016 06:21 PM
  5. DFranch's Avatar
    I took a picture in a dimly lit restraunt (no flash) over the weekend, i was happy with the result.
    Tatt2014 likes this.
    03-21-2016 10:30 PM
  6. paridge's Avatar
    Fantastic! Takes great pictures. If you're into photography, it's Samsung’s best iteration of pro mode thus far. The benefits of the ability to shoot RAW + the ability to now control shutter speed can't be overstated. Even the implementation of white balance and exposure controls is improved.
    03-22-2016 03:25 AM
  7. torbach1's Avatar
    Best I've ever used on any phone. It focuses instantaneously, gets absolutely terrific photos and video. Better than the S6 Edge+, and better than the Nexus 6P.
    03-22-2016 03:35 AM
  8. Kingsfoil's Avatar
    I'm pretty disappointed with the video recording, as after about 30 seconds to a minute of recording mine starts jittering and then just freezes. Using Full HD with image stabilisation on, recording to a Class 10 sd card. Trying a different app, otherwise swapping to a different phone.
    03-22-2016 04:57 AM
  9. torbach1's Avatar
    I'm pretty disappointed with the video recording, as after about 30 seconds to a minute of recording mine starts jittering and then just freezes. Using Full HD with image stabilisation on. Trying a different app, otherwise swapping to a different phone.
    I would consider replacing the unit. It sounds faulty. I took a bunch of 2 min videos of my daughter figure skating on Sunday and didn't experience any issues. The phone's ability to stay focused on her throughout was insanely good.
    03-22-2016 05:01 AM
  10. Phillip Pugh's Avatar
    The camera on this thing is a beast I also have the note 5 and outdoor pictures are about the same but in door is where the gs7 shines and the auto focus is crazy good
    03-22-2016 06:40 PM
  11. erasat's Avatar
    Have you tried recording to the phone storage instead of the SD card just to rule out SD card performance issues and not the phone?
    03-22-2016 06:56 PM
  1. Opening S Note files(.snb) on Huawei G8
    By sajjad zarrinmalek in forum Huawei G8
    Last Post: 11-09-2016, 07:55 PM
  2. Epic Fail!: My horror story of moving apps to the SD card
    By barskin in forum Samsung Galaxy S7 edge
    Last Post: 06-18-2016, 11:46 AM
  3. How much memory is coming with the LG G5?
    By AC Question in forum LG G5
    Last Post: 03-22-2016, 04:50 PM
  4. Does the S7 camera record in 4k?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-21-2016, 10:12 AM
  5. S7 vs LG (Washing Machine)
    By flumdog in forum Samsung Galaxy S7 edge
    Last Post: 03-21-2016, 09:50 AM
