1. AC Question's Avatar
    Help. I don't know why or how this happened but all my Galaxy S7 Edge icons have completely reversed, almost as if it has turned into a left-handed mode. Everything is reversed. Icons, search bar, navigation, etc. I can't find the option to restore it. I even did a reset settings (NOT factory reset) and the icons are still reversed. Even the header navigation is reversed too. Thank you
    03-21-2016 11:17 AM
  2. anon(632115)'s Avatar
    03-21-2016 11:50 AM
  3. TheRussT2112's Avatar
    I had the same problem, but I stumbled upon the solution!
    Go to Settings... Search for USB Configuration. When the pop-up window appears, click "cancel".
    On the bottom of the page, find "Force RTL layout" and turn that off.
    That's it!
    Hope this works for you like it did for me!
    06-06-2016 06:35 AM
  4. carathbunjr's Avatar
    thank you soooooooooooooooooo much!!! why is it that forum members come up with the right solution and "level 2" verizon tech support just reads from their script: use factory reset. Glad I checked here 1st.
    06-26-2016 10:08 PM
  5. mikekimo's Avatar
    wow. so simple . thanks
    09-19-2016 01:29 PM
  6. lazuhrus's Avatar
    Thank you Thank you Thank you!
    03-11-2017 04:38 PM
  7. nicola grady's Avatar
    amazing I really panicked there for a while this also works for the S8
    03-20-2018 09:20 AM
  1. How do I stop text messages from forwarding to my email on the S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-02-2017, 01:23 PM
  2. Help with using Galaxy S6 headphones with a Galaxy S5
    By EdelweissArnold in forum General Help and How To
    Last Post: 03-21-2016, 11:09 AM
  3. Replies: 0
    Last Post: 03-21-2016, 11:04 AM
  4. Samsung s7 drops from 4G+ to H after restarting?
    By yglen in forum Samsung Galaxy S7
    Last Post: 03-21-2016, 11:00 AM
  5. How do I set my android to send calendar alerts?
    Last Post: 03-21-2016, 10:55 AM
