1. ksm09's Avatar
    For the moment i have only the case, but i plan buying a tempered screen protector. How well do you think they will get along together, i'm worried that the case will peel of the screen protector, but i also know the tempered ones are pretty strong for that. What do you think guys ?
    03-21-2016 03:39 PM
  2. dpham00's Avatar
    Hard to tell. Depends on the case and screen protector
    03-21-2016 04:16 PM
  3. brava27's Avatar
    Glass screen protector don't peel
    03-21-2016 04:23 PM
  4. Frank Aiello's Avatar
    They do if they are too large for the case. I used spigen glass and spigen cases on my S4 and S5 without any problems but did have a problem with a different brand on my S4 but don't remember who. Hopefully Spigen will come out with one soon, I am going without until then as I do not like the non glass type.
    03-21-2016 06:38 PM
  5. felloffthetruck's Avatar
    Yes, any case will peel the edge to edge glass protectors up.
    03-21-2016 06:45 PM
  6. larry44's Avatar
    I had the Spigen neo hybrid case and loved it on my 7Edge. Then the Luvitt screen protector was shipped but it doesn't play well with the case. It's just a bit too tight and finger movements in the upper and lower areas of the screen don't register. So now I'm using only the protector. I ordered the matching Luvitt case which says online that it will work well with their protector. I'll post again when it get it. I'm ultimately waiting for the Zagg glass and hope it will work with the Spigen case.
    03-21-2016 07:27 PM
  7. gnuser's Avatar
    I was waiting for the Luvvitt glass also. Have the neo hybrid cases one with the black cover on the back. What is the issue when you say tight? I have at least 1.5 mm between the edge and the cover on the sides.
    03-22-2016 11:53 AM
  8. Almeuit's Avatar
    I wish Spigen would put their cases on Amazon .
    03-22-2016 11:55 AM
  9. dman76's Avatar
    Order the Spigen cases from their eBay store. I just got the Neo Hybrid for $16. I originally bought the Slim Armor from Amazon because I loved that case on my old phone but the buttons were hard to push and almost impossible to find by feel in the dark. So I returned that and bought the Neo Hybrid. Very nice case with excellent grip.
    ksm09 likes this.
    03-22-2016 01:37 PM
  10. LdotAdot13's Avatar
    Did they recently stop? I've gotten all my Spigen through Amazon
    03-22-2016 01:42 PM
  11. dman76's Avatar
    Yeah I don't know what happened. They were all on there 2 weeks ago before this phone was released and I actually ordered one on the 8th or 9th. When I went to check back there to order the Neo Hybrid because I returned the other one, they were all gone.
    03-22-2016 01:44 PM
  12. Almeuit's Avatar
    For the edge? Where at? I search and don't see it on Amazon.
    03-22-2016 01:48 PM
  13. LdotAdot13's Avatar
    I just had these 2 deliver last week
    Attached Thumbnails Spigen neo hybrid case plus tempered screen protector-44187.jpg
    03-22-2016 01:52 PM
  14. Almeuit's Avatar
    Ah yeah -- If you check now they are all unavailable.
    Attached Thumbnails Spigen neo hybrid case plus tempered screen protector-untitled.png
    03-22-2016 01:56 PM
  15. sangs's Avatar
    Probably because they ran such great specials on Amazon and they all got snapped up. They had them for $4.99 a couple weeks back.
    03-22-2016 02:00 PM
  16. larry44's Avatar
    It tended to squeeze the edges causing the top and bottom to lift up just enough so the screen wouldn't react to my touches.
    03-22-2016 04:18 PM
  17. amrunner4's Avatar
    I had the Spigen neo hybrid and returned it thru Amazon. Not enough grip on the edges. Also the cutouts at the bottom did not fit my headphone jack nor my aftermarket micro USB plug - they are cut just a little too small. Got a Speck CandyShell Grip case instead. MUCH better and secure grip
    03-22-2016 04:25 PM
  18. shane starr's Avatar
    yep me too.
    03-23-2016 08:50 AM
  1. Who Is Using a Leather Flip/Wallet Case for S7 Edge?
    By LSWMW in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 06-18-2016, 04:05 AM
  2. Missing lock screen notifications?
    By jackson495 in forum Samsung Galaxy S7
    Last Post: 03-22-2016, 02:12 PM
  3. Replies: 1
    Last Post: 03-21-2016, 02:30 PM
  4. Replies: 0
    Last Post: 03-21-2016, 02:00 PM
  5. Weird Google Plus pop up after update, how do I make it stop?
    Last Post: 03-21-2016, 01:41 PM
