Has anyone able to block ads using the default browser on their tmobile s7/ s7edge? I already downloads the crystal adblock but I cant find an option in setting to block ads.
Adguard is nice but can't stand that key icon all the time in the upper left corner of the screen.
Adguard seems to work beautifully on my s7 edge. Thanks!
I don't mind the key icon that shows at the top of the screen one bit. They're talking about doing away with that in a future update.
[APP][4.0+] NetGuard - No-root firewall [2.1… | Android Development and Hacking
https://block-this.com/
Both free, both block ads in apps and all browsers.
I love Adguard and it seems to work better than anything else. They have a thread on XDA where you can report an app that Adgurad isn't blocking ads in and they will fix it very fast.
Yeah that's what i thought. Still it is annoying. Browser addon adblockers doesn't require such icons to be persistently on the screen so that's a win. Such as crystal.
Thanks gotta try that netguard.
In my opinion, nothing beats being able to block ads in apps as well. I can't think of anything more annoying that having to look at a full screen ad before I can even do anything inside that app as many of them force you to do. Then there are the redirects that take you to the play store. Those problems go away when you block ads in apps.On the other hand, browser add-ons don't block ads in apps.
