Has anyone able to block ads using the default browser on their tmobile s7/ s7edge? I already downloads the crystal adblock but I cant find an option in setting to block ads.
Printable View
Im using Adblock Fast designed for Sa,sung browser 4 and up. It works well and is configured through the browser
I have ad block fast and Samsung browser and still can't get it to work. Ad block does not show in the settings. - Tmobile
Try "adguard " from xda forums. It blocks ads in any browser and app. Doesn't require root either.
That adguard is the only one that works! I love that app, blocks the video ads on YouTube and all! I have it on my S6 and S7.
Adguard is nice but can't stand that key icon all the time in the upper left corner of the screen.
And it didn't block in app ads for me.
[APP][4.0+] NetGuard - No-root firewall [2.1… | Android Development and Hacking
https://block-this.com/
Both free, both block ads in apps and all browsers.
That's an Android notification that a VPN is in use, and there's really no way to block ads in all apps without using the VPN, unless you're rooted.
Yeah that's what i thought. Still it is annoying. Browser addon adblockers doesn't require such icons to be persistently on the screen so that's a win. Such as crystal.
Thanks gotta try that netguard.
Adguard seems to work beautifully on my s7 edge. Thanks!
I love Adguard and it seems to work better than anything else. They have a thread on XDA where you can report an app that Adgurad isn't blocking ads in and they will fix it very fast.
I don't mind the key icon that shows at the top of the screen one bit. They're talking about doing away with that in a future update.
The key isn't a problem, but it shows 2 keys for me.
One thing I especially like about using Adguard is that it gets me into sites that are blocking adblocker users, using the Samsung internet browser.
I did a google search today for sites that are blocking users who use adblockers and I was able to get into all the sites. Tried those same sites using Adaway on a rooted Note 4 and was blocked from visiting those same sites.
I think the one with the key is Netguard which can also block ads. Adguard plugin for the internet browser that comes with S7 is different--and nicely seemless.
Have you tried both compared to Adguard (premium)? Any bullet points opinions on differences/preferences/what's best?
Thanks for your mention of Adguard a while back in another thread. I'm giving it a go with the year subscription.
On the other hand, browser add-ons don't block ads in apps.
In my opinion, nothing beats being able to block ads in apps as well. I can't think of anything more annoying that having to look at a full screen ad before I can even do anything inside that app as many of them force you to do. Then there are the redirects that take you to the play store. Those problems go away when you block ads in apps.
Trying adguard but can't find a way to report ads found on webpages?
And it seems that in-app ads can only be blocked via premium version of the app?
It should be blocking ads in apps during the one week free trial.
For me it doesn't. Only in browser.
Tried in a game and YouTube, both had ads.
And you have Adguard turned on?
Attachment 224773
Yup
