1. Rumblee1's Avatar
    My S7 wifi connection will just disconnect when the phone hasn't been used for a while. This morning it happened again. I got up, tried to go on line but kept getting a "no connection, try again" message even though my wifi was connected and I had a great signal. The minute I rebooted, it came back to normal. Anyone else having this issue?
    03-22-2016 07:12 AM
  2. StuffOfInterest's Avatar
    By chance are you on AT&T and have the AT&T smart wifi app enabled? I had the same issue and traced it to this app shutting down my wifi when it thought I wasn't close to an access point. This would happen to me at home being that I would lose location lock inside the house. Either disabling the app or changing it to never turn off wifi fixed the issue for me.
    03-22-2016 07:24 AM
  3. Rumblee1's Avatar
    No, im on Verizon.
    03-22-2016 07:57 AM
  4. spridell's Avatar
    I have T-mo and it happens to me when there has been long periods phone not in use.
    From what I have read this is a Marshmallow bug thats been going on for a while and has not been fixed.
    03-22-2016 08:47 AM
  5. Rumblee1's Avatar
    If you are correct, that's fine. But I'm noticing that when I'm hooked up to my extender, I have problems. When I hook up directly to my modem, it's OK. The weird thing is that I get a stronger signal from my extender.
    03-22-2016 09:34 AM
  6. Rheller82's Avatar
    Have you tried disabling your Bluetooth?
    03-24-2016 04:07 PM
  1. Unfortunately, com.samsung.ipservice has stopped
    By ogio in forum Samsung Galaxy S7 edge
    Last Post: 04-09-2018, 07:35 PM
  2. Error "Unfortunately backup has stopped": How do I fix?
    Last Post: 07-07-2016, 07:58 AM
  3. power button stopped working
    By Nkky7 in forum Samsung Galaxy S7 edge
    Last Post: 04-08-2016, 02:27 PM
  4. Device keeps hanging while installing apps. Why is it doing this?
    Last Post: 03-22-2016, 07:54 AM
  5. I want wifi and mobile internet to work together, how can I do this?
    Last Post: 03-22-2016, 04:44 AM
