07-10-2016 09:31 AM
64 123
tools
  1. pwinters's Avatar
    Yep - you read the title right. I was showing off my water-resistant capabilities to my family by holding it under the faucet. Water ended up behind the lenses on both sides of the phone and under the LED. Could not take any pictures. Best Buy told me I should call Samsung, which I did. They said their policy doesn't allow them to cover damage from liquid. My response: "when you air commercials every 5 minutes with Little Wayne dunking it into a fish tank and pouring a bottle of champagne on it, you're damn right you do". Needless to say I didn't get anywhere with them. So I returned it to Best Buy and ordered one direct from Sprint. Just an FYI!
    03-22-2016 11:13 AM
  2. Almeuit's Avatar
    It sounds like yours may jsut not have been sealed and may have been defective. Samsung should have replaced that .. shocked they didn't.
    03-22-2016 11:16 AM
  3. dpham00's Avatar
    It seems defective... Running it under a faucet should be ok.
    03-22-2016 11:22 AM
  4. pwinters's Avatar
    It was, in my opinion, which is why it went back to Best Buy! They were great about it, btw. They said that shouldn't have happened and let me return it no questions asked. I would have let them replace it, but they weren't supposed to get any in the silver for a while.
    03-22-2016 11:26 AM
  5. meyerweb#CB's Avatar
    We all need to understand what the IP86 spec says, what it means, and what Samsung says about water. THIS IS NOT A WATERPROOF PHONE.
    The 8 in IP68 means the phone can sit in still water. Not flowing water or water under pressure. There are different IP specs for that. And a higher number doesn't automatically mean a higher level of protection. IPx1 through IPx4 are for splashing water, with 1 being equivalent to light rain, and 2 through 4 progressively harder. IPx5 and 6 are for flowing water. The fact that something passes an IPx8 test doesn't mean it also passed, or will pass, a flowing water standard. Flowing water applies pressure to openings that simply sitting in water might not.
    Not soapy water (yeah, there was a thread about that on another forum). Soap acts as a lubricant, and makes water more slippery, and could allow water to infiltrate openings that plain water won't.
    Not salt water, or water with other contaminants (don't wash your phone is a mixture of water and clorox!). That should be obvious.
    Finally, what does Samsung say about water?
    Do not expose the device to water moving with force, such as running water from taps,ocean waves, or waterfalls
    All that said, I agree that Samsung's advertising is a bit misleading, and the warning not to expose it to water from taps is not made clear in any of the materials a new owner is likely to see.
    03-22-2016 06:12 PM
  6. bsteppuhn's Avatar
    my friend asked me to do this and I said NOPE. I'm not taking that chance! I understand its water resistant proof water but I'm not going to purposely stick it in there lmao! kudos to you that have the balls enough to do it! I certainly don't!
    jneusch and Hectorius like this.
    03-22-2016 07:03 PM
  7. flintlock's Avatar
    Isn't there a specific disclaimer in the warranty regarding water?
    03-22-2016 07:07 PM
  8. limitbreak09's Avatar
    Dang balls of steel! But we're glad that you got a replacement. Just show your fam how the samsung pay works and they will be blown away. Make sure it works first lol.
    -S7Edge
    makaroni likes this.
    03-22-2016 07:14 PM
  9. pwinters's Avatar
    Does that include liquid flowing from a champagne bottle, I wonder?
    ckelly33, ilhe1s and Liskrig like this.
    03-22-2016 07:41 PM
  10. rong21's Avatar
    I have an S6 Active and a couple of folks did the same with the same results. Samsung wouldn't replace or fix.
    I won't even try it because of that
    nj1266 likes this.
    03-22-2016 07:47 PM
  11. teristark's Avatar
    My husband's s5 was dropped in the hot tub and the Samsung repair shop took it in, did a pressure check and replaced his phone. The service there was excellent. If either of our S7s go haywire I will take them there rather than TMO.
    03-22-2016 08:19 PM
  12. meyerweb#CB's Avatar
    Yeah, that's part of what I consider misleading advertising.
    We need to view the water resistance as something that will help prevent damage in the event of accidental exposure, not something that will protect the phone from deliberate water exposure.
    nj1266 likes this.
    03-22-2016 09:53 PM
  13. pwinters's Avatar
    I'm starting to come around to that line of thinking.
    03-22-2016 10:57 PM
  14. Jaycemiskel's Avatar
    There's too much pressure from running water. The phone wasn't defective. You want to take it swimming, you should be fine, but like they said the pressure is too great from flowing water. That's why you can't go below a certain depth with the rating they give. The deeper you go, the higher the pressure
    03-22-2016 11:15 PM
  15. pwinters's Avatar
    Guys - the pressure on this faucet was not that strong. I want to stress that it's not like I held it to the end of a fire hose. This was a gentle, soft flow of water and I do not believe I did anything wrong here. Samsung should have known full well when they started advertising this feature in the way that they have that people were going to get it wet in any way that they could. They are actively pitching this feature as the main attraction.
    nj1266, teristark, bembol and 2 others like this.
    03-23-2016 08:14 AM
  16. Lobwedgephil's Avatar
    Really doesn't matter if its not that strong, it says don't expose the phone to running water. Any running water is more then the phone is certified for. I agree that the way Samsung advertises the feature makes it confusing, and they probably shouldn't but it is what it is. Either way, glad it worked out for you and you were able to return it.
    03-23-2016 09:20 AM
  17. Almeuit's Avatar
    They know that -- They're just saying there is a lot more pressure if you compare water sitting in a glass versus water flowing out of a faucet. The rating they gave this phone is not meant for "proofing" the phone. It is more so meant for accidental spills or if you're talking on the phone and it starts to rain some you won't have to freak out and worry about your phone.
    This is true but ... As with any advertising you always have to read the bottom of the screen or the "details". If I went with everything I saw on TV / advertisements life would be great .. But you always read the fine print and say "Ahh I see what you're doing".
    03-23-2016 09:26 AM
  18. dpham00's Avatar
    Samsung directs you to rinse it with fresh water if it comes in contact with another liquid. I take it that a typical water faucet should be ok, assuming that you are not using steaming hot water.
    Please also see my thread on maintaining water resistance:
    http://forums.androidcentral.com/sam...ps-manual.html
    flintlock likes this.
    03-23-2016 09:46 AM
  19. ClintRo's Avatar
    Sounds like they should have covered the "Faucet" damage.
    1812dave likes this.
    03-23-2016 10:15 AM
  20. anon(607340)'s Avatar
    Yes, however, the Samsung manual says to rinse your phone off if other liquids (besides regular water, such as pool water) get on it.. why would they tell you to "rinse it" if you can't use running water? How would you do that?
    03-23-2016 10:37 AM
  21. Rukbat's Avatar
    Because advertising, marketing and engineering haven't had that meeting yet - in which engineering tells everyone to knock off the "phone is waterproof" nonsense. There is one of those. The Navy uses it. It costs more than my house. But it's waterPROOF to 400 feet of ocean water for at last 24 hours. (And no, it's not available unless you can place Navy orders.)
    For anything else, it's water resistant, not waterproof. A plain plastic zip lock bag is more waterproof (and I use them all the time if there's a possibility of the phone getting wet).
    All the "water resistant" hype is just that - hype. Treat ALL phones as if there's no such thing as IP68, and they won't get water damaged.
    nj1266 and Not Quite Right like this.
    03-23-2016 01:08 PM
  22. natehoy's Avatar
    Or even just treat IP68 as IP68, and not IP64-IP66 (which DO actually speak about water under pressure as opposed to immersion in still water). Though, granted, treating an IP68 phone as IP00 means it will never let you down.
    It's really a shame that the IP standard is so unnecessarily complicated. Immersion really needs to be a third number and not a "reset/extension" of the water ingress (second number) that means moving water from 1 (light rain) to 6 (pressurized hose) and suddenly changes to "still water" in 7 and 8. Because people look at IP68 and think "that has to be better than IP66!" When it's clearly not. It's an entirely different type of ingress protection.
    03-23-2016 01:26 PM
  23. bigslam123's Avatar
    Not to mention that, in the commercial, he is pouring the champagne on a flat facing phone. Most of the liquid was being deflected away by the screen.
    03-23-2016 01:32 PM
  24. ClintRo's Avatar
    Ok.... i am confused and my head hurts now.... Thanks. what day is it again?!?!
    03-23-2016 01:32 PM
  25. natehoy's Avatar
    LOL. Fair enough.
    https://en.wikipedia.org/wiki/IP_Code
    First number is for solids. IP0x = no protection. Then it goes up from "nothing bigger than a baseball can get in" to "nothing as big as dust can get in", (IP6 is the highest rating, basically, and means "very dust resistant"). This is a very logical progression from "you can fit a baseball in" to "you cannot fit dust in". It makes sense.
    Second number is for liquids. It starts out clearly enough. IPx0 = no protection. IPx1 = water falling vertically. IPx2 = water falling at an angle. IPx3 = water falling at a more severe angle. IPx4 = water splashing against the enclosure (gently) at any angle. IPx5 = water being sprayed at the enclosure under light pressure from any angle. IPx6 = water sprayed under significant pressure at the enclosure at any angle. So you see a logical progression here - water falling vertically progressing to water under significant pressure from any arbitrary angle. 1 to 6 makes plenty of sense.
    This is where things get complicated. IPx7 = immersion in still water of a meter or less and IPx8 is a meter or more, with the depth specified by the manufacturer. So by going from 6 to 7 we've suddenly dropped from "can tolerate a garden sprayer pointed at it" to "can be immersed gently in shallow still water"
    The upshot is that your IP68 certification means nothing with regards to a sink tap. You need an additional IP64 or preferably IP65 certification for that. Because 7 and 8 only mean "still water", and a sink tap exerts pressure from the water falling.
    Not Quite Right and ClintRo like this.
    03-23-2016 01:56 PM
64 123
  1. Why do the pictures on my S7 look grainy?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-22-2016, 06:20 PM
  2. Messed Up Superimposed Notification Icons Upon Waking Up S7 Edge!!
    By Dualmonitors in forum Samsung Galaxy S7 edge
    Last Post: 03-22-2016, 12:14 PM
  3. Replies: 0
    Last Post: 03-22-2016, 10:11 AM
  4. S7 edge problem reading attachments
    Last Post: 03-22-2016, 09:41 AM
  5. Replies: 0
    Last Post: 03-22-2016, 09:39 AM
