1. AC Question's Avatar
    What is the max I can get for memory on my S7 Edge?
    03-22-2016 04:48 PM
  2. Lobwedgephil's Avatar
    03-22-2016 05:10 PM
  3. ABOSWORTH007's Avatar
    200GB SD card.
    03-22-2016 05:10 PM
  4. Adiliyo's Avatar
    technically you can put in up to 2TB (the limit of the sd card slot) but being that no card larger than 200GB exists at the moment, samsung listed 200GB as the max.
    03-22-2016 05:50 PM
  5. bsteppuhn's Avatar
    are you asking what is the max after you put in a card? Are you asking if you put in a 200g card if it is really 232g of memory? Or are you looking after you have inserted and formatted what the leftover is?
    03-22-2016 05:56 PM
  1. How is the camera on the S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-23-2016, 12:37 PM
  2. Replies: 1
    Last Post: 03-22-2016, 09:51 PM
  3. What OS does the S7 come with?
    Last Post: 03-22-2016, 05:47 PM
  4. How is the camera on the S7?
    Last Post: 03-22-2016, 04:58 PM
  5. What OS does the S7 come with?
    Last Post: 03-22-2016, 04:57 PM
