1. Iain Johnson's Avatar
    Anyone know of an app for the edge that displays the football scores (soccer)?
    When you go into the download part of the edge it only has like 5 apps.. I presume I'm missing something simple.
    Cheers
    03-23-2016 09:57 AM
  2. Lobwedgephil's Avatar
    Yahoo sports edge app will show Premier league.
    03-23-2016 10:05 AM
  3. DEman19901's Avatar
    There are some soccer league scores in the Yahoo sports app. I do not know the difference in the leagues as for I do not follow soccer.
    03-23-2016 10:06 AM
  4. tshirttan408's Avatar
    We can't get the yahoo app (yet) here in the UK. Or at least if you get a file manager and go in you can get it to install but it doesnt work
    03-23-2016 12:39 PM
  5. Iain Johnson's Avatar
    Ah OK no worries. The Samsung kick app is pretty good and it has the edge lighting for goals update, so maybe they are working on it.
    03-23-2016 01:45 PM
  6. Scutley's Avatar
    I recommend downloading scores widget in Google Play. It's a really nice widget to view any score from any sport from any team.
    03-23-2016 04:11 PM
  1. S7 Edge with High Quality Headphones
    By JAG21979 in forum Samsung Galaxy S7 edge
    Last Post: 02-16-2017, 07:34 AM
  2. Trouble with Edge Feeds
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-23-2016, 05:51 PM
  3. S6 Edge loosing wallpaper after marshmallow update
    By rahadfield in forum Samsung Galaxy S6 edge
    Last Post: 03-23-2016, 04:47 PM
  4. Not seeing all EDGE feeds
    By ep70 in forum Samsung Galaxy S7 edge
    Last Post: 03-23-2016, 09:38 AM
  5. Replies: 2
    Last Post: 03-23-2016, 03:43 AM
