1. rdimedic's Avatar
    How can I change where photos are saved? I'm wanting all my pictures I save to go straight to my SD card.
    03-23-2016 03:55 PM
  2. mavrrick's Avatar
    Open the camera app an tell it to go there in the settings. My phone detected the SD Card and told me it was doing it automatically.
    rdimedic likes this.
    03-23-2016 03:58 PM
  3. ClintRo's Avatar
    03-23-2016 03:58 PM
  4. ZMc1834's Avatar
    I would like this question answered as well. I have my camera set up to save to my SD card. I can't find the setting to save pictures received via most, email, etc to my SD card. Also screenshots are being saved to internal storage, is there a way to change that?
    03-23-2016 04:10 PM
  5. yomny Martinez's Avatar
    Basically everything done related to pictures will be saved once again in the 'internal memory" such as edited phots, downloaded, wallpapers from zedge... I've been struggling with this, moving each folder(file) created to my SD card but I've given up. Only pictures taken with camera will go to SD(if setup to do so). If this isn't the case or someone knows different, please share.
    03-23-2016 04:15 PM
  6. dpham00's Avatar
    Keep on mind that bursts will be saved to internal memory
    03-23-2016 04:59 PM
  7. ClintRo's Avatar
    The Gear icon on top of the camera opens camera settings. Then scroll down to storage location. Change it to internal.
    LanceAllan likes this.
    03-23-2016 05:18 PM
  8. rdimedic's Avatar
    https://uploads.tapatalk-cdn.com/2016...78a40d972f.jpg
    https://uploads.tapatalk-cdn.com/2016...ec9654e443.jpg
    How do I change where pictures are saved? Like for example...ones I download from the Internet or email. Also screen shots.
    03-23-2016 07:47 PM
  9. ClintRo's Avatar
    You may have to use the file manager to move those.
    My Files is the app name
    03-23-2016 08:00 PM
  10. Stephanie Miller4's Avatar
    If you open the camera app and see a little SD card icon near the top right it's saving to the card. Mine did it automatically once I popped the card in
    03-23-2016 08:26 PM
  11. ZMc1834's Avatar
    We know that the pictures taken on the phone with the camera are going to the SD card. What we are trying to figure out is how to save other pictures from Internet, mms, email, etc to the card without having to go into the file manager and move them afterwards.
    03-23-2016 09:13 PM
  12. ClintRo's Avatar
    It would be in the particular apps settings
    03-23-2016 10:24 PM
  13. makaroni's Avatar
    As far as I know, this is not possible. You have to manually move those. It's different from a pc where you hit "save as" and you can choose the destination folder. Just saves internally automatically.
    03-24-2016 01:50 PM
  1. Official Twitter App Won't Save Notification Tone
    By KPMcClave in forum Samsung Galaxy S7 edge
    Last Post: 06-23-2016, 08:32 AM
  2. Replies: 1
    Last Post: 03-23-2016, 03:38 PM
  3. No connect with my device, only saved.
    Last Post: 03-23-2016, 02:32 PM
  4. Replies: 1
    Last Post: 03-23-2016, 02:21 PM
  5. Replies: 0
    Last Post: 03-23-2016, 12:26 PM
