1. wafcarl's Avatar
    Had iPhones & on connection to Audi Music Interface all tracks, albums, playlists etc show & you control from steering wheel.
    On trying this, all I get from interface is "next" or "previous" all albums, playlists or track info is gone. Do you know if I should get all the stuff or was it simply an iPhone thing? If it was only iPhone, if I transfer my music to SD Card & put that in will it work same?
    03-23-2016 07:17 PM
  2. brava27's Avatar
    I am not rich unfortunately ๐Ÿ˜๐Ÿ˜†
    03-23-2016 07:39 PM
  3. PhiPsi32's Avatar
    Never had much luck with AMI. iPod works OK. Disconnects sometimes and I have to unplug/replug to get it started. Tried the SD card slot. Never got that to work. Switched to satellite radio.
    03-23-2016 07:51 PM
  4. jdh4's Avatar
    I have an audi S5 but have never connected the samsung S5 or new s7 edge to it just use the audi wifi in the car and listen to sirus/xm most of the time I did put some music on a sd card as it has 2 sd card slots plus the Sim for the cellular wifi in the car and it will read all the folders and play the songs from the folder so you can make a Playlist just put all the songs you want into that folder
    03-23-2016 09:40 PM
  5. jmm22's Avatar
    It works for me on Bluetooth connection. Tried it on my S8 and Q7. They did change the media interface with the 2017 Q7 though, not as good IMO.
    03-23-2016 11:00 PM
  6. Asfalloth's Avatar
    Works for me on my A4 Avant 2016, I see all the track names etc. as normal.
    03-24-2016 09:08 AM
  7. henrykrinkle's Avatar
    I cannot stream music in my 2011 Q5 (calls only-limitation of the car) but I have had the related problem of not being able to import my contacts from the phone. I've had HTC phones for years (most recently, the M9) and never had this problem. My guess is that the Audi MMI doesn't play well with Samsung phones.
    03-24-2016 10:19 AM
  8. Asfalloth's Avatar
    That's weird all my contacts appear in the audi phone app just fine.
    Just a thought but just after you pair the phone to the car with Bluetooth it normally pops up with an allow access to phone contacts message on the phone, did you get that message?
    if not perhaps delete phone from car and phone and try again?
    03-24-2016 10:47 AM
  1. Help! Contacts disappearing!
    By mikeinstlouis in forum Ask a Question
    Last Post: 03-29-2016, 11:12 AM
  2. Help - my Samsung Note 8.0 is stuck in SDCARD MODE
    Last Post: 03-23-2016, 10:48 PM
  3. i dropped my phone- help?
    Last Post: 03-23-2016, 06:50 PM
  4. NEED YOUR HELP!! Need tab 3 T215 8GB debrick image.
    By izarsha in forum Samsung Galaxy Tab 3
    Last Post: 03-23-2016, 05:23 PM
  5. Weather app with tide widget help
    By tgrsnpr in forum Android Apps
    Last Post: 03-23-2016, 05:03 PM
