1. Woodly57's Avatar
    I get the following message when I power on my new S7 Edge:
    "Process system isn't responding. Do you want to close it"?
    Wait / OK.
    No matter which I click, the message goes away and everything seems fine.
    Any ideas?
    03-23-2016 10:34 PM
  2. Mooserman15's Avatar
    Do you have root? If you don't know what I mean, then you don't have root. This is likely a glitch. It happens when the system gets extremely laggy. I have this constantly on my Galaxy Tab 2 10.1. What's amazing here? If csrss, the Windows equivelent of Process System, stops, Windows BSOD's.
    03-24-2016 12:13 AM
  3. belljs's Avatar
    reformat the sd card in the s7 …,do not copy files in the sd slot of your computer..leave the sd card in the s7…use the s7 as an external drive and copy your files..problem is windows doesn’t care about long file names but the s7 does….the s7 will point out actions when you try to copy a file w a long file name
    08-21-2016 05:57 AM
  1. How do you respond on the forums?
    By AC Question in forum Site Feedback & Help
    Last Post: 03-28-2016, 09:51 AM
  2. Replies: 1
    Last Post: 03-24-2016, 01:23 PM
  3. How do you respond on the forums?
    Last Post: 03-23-2016, 09:23 PM
  4. My new Galaxy S7 isn't installing anything.
    By Tetrisash in forum Samsung Galaxy S7
    Last Post: 03-23-2016, 02:45 PM
  5. App or contract specific notifications don't respond to vibrate mode??
    By Teresa Anna in forum Android 6.0 Marshmallow
    Last Post: 03-23-2016, 02:04 PM
