1. Rumblee1's Avatar
    Im loving my S7 edge. I thought marshmallow was supposed to have the DOZE. feature? Is it built into the software? Can you access it at all? I can't find it anywhere.
    03-24-2016 04:48 AM
  2. the tall guy's Avatar
    Yeah it's not an app, it's a background task that helps the battery. You probably won't see anything unless you leave it idle for a couple of hours then check your battery stats.
    03-24-2016 04:57 AM
  3. dpham00's Avatar
    Settings - battery - more - optimize battery usage
    munnarg and pinkvikchick like this.
    03-24-2016 07:13 AM
  1. Why is Android System draining my S7's battery?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-24-2016, 10:04 PM
  2. How do i see whats on sd card that is in phone
    Last Post: 03-24-2016, 09:43 PM
  3. What is Beautifulbitstarter app ?
    By AC Question in forum Android Apps
    Last Post: 03-24-2016, 03:50 AM
  4. Replies: 1
    Last Post: 03-24-2016, 02:33 AM
  5. Why is my usb connection on my S3 mini not showing in the pc?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 03-24-2016, 02:29 AM
