I know this is the S7 forum but if the 6P had ip68 water resistance and the S7s canera, would you choose the 6P over the S7/edge ?
Or you could be like MizWylie and own both.
Posted from the S7E Chrome™ on Big Red
Go to best buy and handle both. I'm sure you'll be happier with the 7e.
IOS on the 7 Edge hardware would be the best.
I Some parts of touchwiz are too ugly,
iOS software on anything is the worst. I don't want a locked down system that tells me how it should work, I want a system that let's me tell it how I want it.
Disagree. iOS is up to date, secure. Is insanely efficient and insanely fast, gets the same battery life with 1/2 the battery size.
Or - buy an S7 Edge, attempt to disable everything that is junk or bloat, and try to get good battery life, deal with bugs like SD card constantly ejecting etc.
An S7 Edge with its superior front and rear camera, great build quality display and body size, 4gbs of RAM etc.. would be perfect if it had iOS on it.
