1. dman76's Avatar
    Ok, I can't believe I can't figure this out but I don't know what I am doing wrong. I put some .mp3 ringtones into the ringtones folder. Then when I go under the sounds menu and to the ringtones, if I click on Add Ringtone, I can't find the file I put in that folder. Is there another way to do this?
    03-24-2016 06:40 PM
  2. Rukbat's Avatar
    Either restart the phone or run media.Re.Scan. Copying files doesn't change the ringtone database.
    03-24-2016 06:59 PM
  3. Iva_LadyDiCaprio98's Avatar
    When you select ring tones scroll to the bottom and select add ring tone and it should let you pick your own ring tone
    03-25-2016 04:37 PM
  4. PDrummo's Avatar
    Hoping someone can help.
    I can choose a ring tone from my sdcard but it wont preview play it or select it as the new ringtone. This is very frustrating as all I can select is the stock ringtones, which suck BTW.
    07-19-2016 11:24 PM
  5. vientiane's Avatar
    yep, that the way it is.
    07-20-2016 02:07 AM
  6. Rachel Rolph's Avatar
    Hi, when I go to the bottom of my ringtones it says add from device storage instead of add ringtone. Can you help me?
    12-14-2016 01:55 PM
  7. Alanhd's Avatar
    I recommend trying Ringdroid. It takes all the hassle out of selecting your own ringtones.
    12-14-2016 02:21 PM
  1. S7 - can't add custom ringtones to my S7.
    Last Post: 04-11-2016, 12:26 AM
  2. How can I update Galaxy S6 Edge to Marshmallow in Brazil?
    By gustavoformiga in forum Samsung Galaxy S6 edge
    Last Post: 04-01-2016, 06:57 AM
  3. How can I completely block WiFi access?
    Last Post: 03-25-2016, 07:52 AM
  4. How to stop notification to sign in on Samsung S4 mini
    By jim Davis5 in forum Samsung Galaxy S4 Mini
    Last Post: 03-24-2016, 05:51 PM
  5. How to schedule "silence" on Sunday mornings
    Last Post: 03-24-2016, 05:42 PM
