1. uktivo's Avatar
    Hi all.
    I use purevpn whilst travelling. It's worked just fine for a couple of years nearly but since I added it to my S7e it will connect but I'm not able to see any Web pages.
    Anyone else have the same issue or any pointers to get it to work please ?
    Update.
    Uninstalled, rebooted and re installed. Still doing the same.
    If anyone has a VPN recommendations. I'd look at them. Needs to work with windows 10 also if possible. Thanks
    03-25-2016 05:50 AM
  2. tiffanyfrancis's Avatar
    Are you getting same issue with all servers or specific one. Switched between OpenVPN UDP and TCP from settings. Also try PPTP and L2TP then check if it resolves your issue.
    03-28-2016 03:03 AM
  3. itguyjax8430's Avatar
    Hi all.
    Update.
    I personally use Private Internet Access as my VPN. I run it on my phone and my server at home, it works with Windows 10 as well.
    uktivo likes this.
    03-28-2016 07:55 AM
  1. Nexus 6P or Galaxy S6 edge
    By docle888 in forum Ask a Question
    Last Post: 03-28-2016, 11:27 AM
  2. Replies: 1
    Last Post: 03-28-2016, 07:29 AM
  3. No 4G LTE connectivity on Droid Maxx
    Last Post: 03-28-2016, 07:19 AM
  4. Samsung Internet for Android Text Size
    By fasali87 in forum Samsung Galaxy S5
    Last Post: 03-26-2016, 09:01 AM
  5. Cannot transfer video when connected to laptop via USB
    By gomezadr in forum Samsung Galaxy S5
    Last Post: 03-25-2016, 05:30 AM
