1. amendolaro's Avatar
    Im getting an error when trying to activate Hotspot- anyone else try this?
    03-25-2016 12:38 PM
  2. amendolaro's Avatar
    Bump
    03-25-2016 03:09 PM
  3. Rheller82's Avatar
    It only works through usb as far as I know. Grr
    03-25-2016 03:41 PM
  4. flintlock's Avatar
    I asked this question in another thread and it was answered affirmatively. Haven't received mine yet. Are you using paid edition?
    03-25-2016 04:02 PM
  5. dpham00's Avatar
    Just use the stock hotspot app. If it doesn't work, contact att for assistance.
    03-25-2016 06:48 PM
  6. amendolaro's Avatar
    I have unlimited data so I can't use the stock hotspot app.
    03-26-2016 03:27 PM
  7. flintlock's Avatar
    Are you using the paid or trial edition? Did you try the PDA net method? The PDA app is the sister app that uses a USB connection.
    I believe you also need to first switch your security to a PIN. You can change back later after it gets working-assuming it does.
    This was on an S4 on Verizon, YMMV. I have an S7E on order (Verizon) so I'm hoping it works for you.
    03-26-2016 03:41 PM
  8. mavrrick's Avatar
    I used both on my note 3 and att sent me a notice saying they were changing my plan to a mobile share plan.
    The unlimited data plan does not allow Hotspot functionality so you are breaking your terms and conditions trying to do so. Switch to a mobile share plan and just use the Hotspot toggle on the phone. That has worked great a few times I have used it.
    03-26-2016 04:07 PM
  1. Galaxy S7 active in the works?
    By Retinella in forum Samsung Galaxy S6 active
    Last Post: 04-25-2016, 03:08 PM
  2. Doze on Verizon Marshmallow, where?
    By dwmitchell61 in forum LG V10
    Last Post: 03-30-2016, 10:16 PM
  3. Firmware Update - S7e on Verizon
    By PJRed2008 in forum Samsung Galaxy S7 edge
    Last Post: 03-29-2016, 02:45 AM
  4. Another update on Verizon!
    By bchain996 in forum Samsung Galaxy S7
    Last Post: 03-25-2016, 07:58 PM
  5. HTC stuck on the home screen
    By dadax in forum More HTC Phones
    Last Post: 03-25-2016, 12:01 PM
