1. johnj2803's Avatar
    I noticed that touching my home button doesn't really unlock fast. I wait maybe a second or two. Unlike the iPhone it unlocks like instantly.
    I'm asking not to trol this thread onto an iPhone vs Samsung thread. I just want to know if this is normal so I can take it back and have it replaced.
    03-26-2016 12:18 AM
  2. ajb1965's Avatar
    It takes about a second for mine to work from completely locked
    03-26-2016 12:31 AM
  3. erasat's Avatar
    If you are talking about the time it takes from a sleep mode to pressing the home button and then unlock, then, there's actually an issue with some SD cards that is causing an unnormal delay in the process. If you are taking just about the time it takes after you have your home screen to unlock the phone, no, there shouldn't be any delay, it may not be as fast as the iPhone but it's close, not normal to take even a second, just fractions of it.
    If you think that it may be also the SD card issue, try removing the SD card and see for yourself how different it is, again, only if that's the case. With a widespread issue like this one, the good news is that a fix can arrive at any moment.
    03-26-2016 01:46 AM
  4. johnj2803's Avatar
    thanks guys!
    03-26-2016 08:00 AM
  5. meyerweb#CB's Avatar
    If my screen is on, but locked, it takes maybe half a second to unlock. From screen off, maybe a second to power on and unlock.
    03-26-2016 09:27 AM
  6. teristark's Avatar
    No issues here either. It is way more accurate/faster than my s6.
    03-26-2016 09:34 AM
  7. erasat's Avatar
    Do you have an SD card on the phone? If so, remove it and see how faster it unlocks compared to the time it takes with the SD card, it seems that is affecting just some cards, it's not with all cards. I just tried this with my S7 and my S7 edge and both are as fast or a little faster than my Note 5 unlocking but once I use my Samsung Pro Micro SD card on it, it gets slower an obvious lag with the screen off.
    There is a whole thread about it over the XDA forums.
    03-26-2016 01:12 PM
  8. MartinMPL's Avatar
    It's fast, the only difference between this and the Nexus 6P/5X is because you have to press the home button - in my opinion.
    Also, I did some sanding yesterday and my fingers are a little bit in ruins. The scanner isn't working today - I guess a win for security!
    03-26-2016 03:39 PM
  1. File read activity in fragment
    Last Post: 03-28-2016, 08:41 AM
  2. Very slow WIFI with s7?
    By rob350 in forum Samsung Galaxy S7
    Last Post: 03-26-2016, 05:35 PM
  3. Verizon variant updates...*slow clap*
    By crazyralph90 in forum Samsung Galaxy S7 edge
    Last Post: 03-26-2016, 09:45 AM
  4. How do I print a text message history from a single contact ?
    Last Post: 03-25-2016, 05:21 PM
  5. Replies: 1
    Last Post: 03-25-2016, 01:00 PM
