1. dency45's Avatar
    Hi Guys. I received my S7 Edge last March 23, so i noticed it last March 24 that when after I woke up i noticed a lot of battery percent is gone. Last night it was 65% then when i woke up it is now 23%. A total of 7.5 hrs in off screen. Anyone experienced this same issue?
    03-26-2016 04:23 AM
  2. t11rmh's Avatar
    What else was your phone doing overnight? Have a look at the battery stats.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    dency45 likes this.
    03-26-2016 04:30 AM
  3. meyerweb#CB's Avatar
    Something's running in the background chewing up battery, I think. Mine dropped from 76 to 69 percent last night. Do you have always on display running? That uses about 1% per hour.
    xocomaox and dency45 like this.
    03-26-2016 09:32 AM
  4. dency45's Avatar
    Here. Always on is activated. I turned off the screen at 7:15am then i woke up at 230pm.
    Attached Thumbnails Consumes a lot of battery even though screen is off.-screenshot_20160326-143335.jpg
    03-26-2016 10:03 AM
  5. PsychDoc's Avatar
    Two likely culprits, BT and low signal strength. Both will kill your battery faster than water running through a strainer. Oh, and BTW, the always - on screen only draws about 0.5% an hour, not 1%.
    dency45 likes this.
    03-26-2016 10:22 AM
  6. xocomaox's Avatar
    There is most likely an app or service keeping the phone from going into Deep Sleep. Check each entry in battery section to see which one has a large wake time.
    Ideally, you should install GSam Battery Monitor and it will give you a good breakdown of what is happening. Good luck!
    dency45 likes this.
    03-26-2016 10:54 AM
  7. dency45's Avatar
    Thanks guys. I will install GSam battery monitor and will update.
    03-27-2016 07:03 PM
  8. dency45's Avatar
    Here is the screen shots. It is still consuming a lot even the screen is off.
    7:30am 37% to 3pm 4% screen is off.
    http://s539.photobucket.com/user/top...w/battery%20ss
    03-28-2016 05:58 AM
  9. DFranch's Avatar
    Your wifi percentage seems high. Mine is never anywhere near 31%-45%
    03-28-2016 12:55 PM
  10. Kevin Harvell's Avatar
    Is your device fully updated and have you tried a factory reset?
    It's possible you got a bad device, but I'd give it a reset before considering returning it.
    03-29-2016 01:05 AM
  11. dency45's Avatar
    Havent tried a factory reset. I just charged it up when it was turned on for the first time.
    Very hassle to factory reset. Need to back up then install again.
    Attached Thumbnails Consumes a lot of battery even though screen is off.-2561.jpg
    03-30-2016 08:02 AM
  12. dency45's Avatar
    What does stay awake mean?
    Attached Thumbnails Consumes a lot of battery even though screen is off.-2562.jpg
    03-30-2016 08:38 AM
  1. I am testing PET film screen protectors on the S7.
    By Mbrigh3 in forum Samsung Galaxy S7
    Last Post: 03-28-2016, 10:20 PM
  2. Recent update killing my battery
    By Rarry in forum Samsung Galaxy Note 4
    Last Post: 03-27-2016, 04:12 PM
  3. Replies: 0
    Last Post: 03-26-2016, 03:43 AM
  4. hydro wave phone stuck on powering off
    Last Post: 03-26-2016, 03:38 AM
  5. Replies: 0
    Last Post: 03-26-2016, 03:16 AM
