1. robcassman's Avatar
    I now have two lock screens. The main default one and the swipe pattern I set up. Any suggestions?
    I will get repeated text messages (the same one) especially if I reset the device.
    I receive an SD card notification to "explore or eject". How do I atop this from showing up repeatedly?
    Thanks!
    03-26-2016 07:25 AM
  2. dpham00's Avatar
    The sd card message should only come up once each time you restart. If it annoys you too much, you can download package disabler from the play store and disable "system ui", which would get rid of the message. I would advise against it though.
    03-26-2016 08:58 AM
  1. How do I restore android os on alcatel one touch
    By theman5142 in forum Legacy Android & Other OS's
    Last Post: 03-25-2016, 09:38 PM
  2. Internet connection issues
    By punishers74 in forum General Help and How To
    Last Post: 03-25-2016, 07:23 PM
  3. Galaxy S6 camera launch issue after marshmallow update.
    Last Post: 03-25-2016, 05:42 PM
  4. Why cant I switch on my HTC one m8?
    Last Post: 03-25-2016, 03:22 PM
  5. Why does my htc one m8 see my brand new sd cart as damaged
    Last Post: 03-25-2016, 01:31 PM
