I want a case that will safe my screen in the event of a face down drop i want depth before the screen a case with a nice thick lip edge on it to save the glass
Do they really? How can there be a raised lip and still be able to swipe the edge?All do
The raised lip is on the top and bottom so you can still lay the phone face first without the screen touching the surface. The sides are partially exposed to allow the swiping. While it's still possible a drop would result in a cracked screen if it falls just right on a side, it seems like a reasonable design choice to have just raised the lip of the cases on the top and bottom.Do they really? How can there be a raised lip and still be able to swipe the edge?
