1. lancashirehotpot's Avatar
    Anybody else in the UK not had the weather widget update the time by an hour even though the phone time has gone forward an hour? Any ideas how to correct it? Tried restarting and removing the widget...
    03-27-2016 02:56 AM
  2. ironass's Avatar
    Is your Date and time in Settings on Automatic?
    Have you tried rebooting your phone?
    My Vodafone time is O.K. Changed at 01.00 hrs.
    03-27-2016 02:59 AM
  3. lancashirehotpot's Avatar
    Yeah its on automatic and tried rebooting it. The phone time is correct it's just the weather widget that's not
    03-27-2016 03:10 AM
  4. ironass's Avatar
    I hate that weather widget. I use Transparent clock & weather, free from the Play Store. Much more accurate and configurable. Try deleting the widget from your home screen and then re-adding it. Hopefully, that should kick it into gear.
    03-27-2016 03:26 AM
  5. lancashirehotpot's Avatar
    Tried it, it did sort itself out briefly but then when I unlocked my phone again had gone back an hour. Never mind, like you say there's loads of alternatives I suppose. Cheers 👍
    03-27-2016 03:29 AM
  6. flintlock's Avatar
    Might there be a setting that sets its time to UTC?
    03-27-2016 04:59 AM
  7. lancashirehotpot's Avatar
    It seems to be related to location. If I turn location off the time adjusts and is correct, then if I turn weather location back on it goes back an hour. This suggests it's possibly an issue at their end?
    03-27-2016 05:40 AM
  8. jaltman's Avatar
    In the US its wrong for about 24 hours and then fixes itself. Just wait.
    03-27-2016 06:53 AM
  9. lancashirehotpot's Avatar
    Ah right, cool thanks. I'll leave it and see what happens
    03-27-2016 09:11 AM
  10. Gator352's Avatar
    I thought dst was a US only thing....
    03-27-2016 04:47 PM
  11. wxman2003's Avatar
    https://en.wikipedia.org/wiki/Daylig...ime_by_country
    03-27-2016 07:33 PM
  12. lancashirehotpot's Avatar
    In the UK the clocks went forward an hour. Sure enough, the widgets sorted itself out now and is correct again. Strange bug.
    03-28-2016 02:24 AM
  13. Gator352's Avatar
    Lol. I just got schooled!
    03-29-2016 04:46 PM
  14. Shejtan's Avatar
    I got this problem on my S6 (going on CET time, living in Sweden) as well. The problem corrected itself after a day or two. However, another, "cosmetic" bug persists. There's this thiny icon that appeared just on the right side of the clock, representing sun with a small clock inside - I assume an indicator regarding daylight savings thing. But it won't go away. I guess this was supposed to be there just the first day or two after the time changed, but it's still there - a week later. Removing / re-adding the weather widget wouldn't fix the problem. I also cleaned the cache from the widget - nothing.
    04-03-2016 02:07 AM
  1. Drive Mode - After MM update won't go off.
    By xdollface8 in forum Motorola Droid Turbo 2
    Last Post: 03-27-2016, 12:40 PM
  2. Forum Super SLOW and Forum TIME is 8 Hours Wrong
    By tzr916 in forum Site Feedback & Help
    Last Post: 03-27-2016, 09:39 AM
  3. Swipe to unlock & fingerprint at the same time
    By AliVardz in forum Samsung Galaxy S6
    Last Post: 03-27-2016, 07:17 AM
  4. Wi-fi slow on G900F( Samsung galaxy s5) after update.
    Last Post: 03-26-2016, 02:42 PM
