1. Dualmonitors's Avatar
    Hi All:
    I've been using 2 non-fast wireless charging stands for a while, then with the S7 Edge, i bought one flat wireless charging stand just to try it out before committing to two of them
    well, it IS a little better than the non-fast one, as i think the "sweet spot" of where one needs to place the phone is a bit bigger, so the chances of successful blue light charging is greater.
    i'm tempted to not buy a 2nd flat fast wireless charging pad (i need two wireless charging things), but instead, buy one of those that's the new tilted fast wireless charging stands.
    may i ask if anyone has any experience comparing the flat fast wireless charging pad versus the tilted fast wireless charging STAND please? is there any performance difference whatsoever?
    thanks.
    i think there are some differences, as the display on the phone looks different on the product page showing off the tilted fast wireless charging stand, so i thought that the new tilted stand might communicate something different to the phone, and thus, maybe there are some performance differences.
    PS: too bad i need the white version of the tilted fast wireless charging stand, and it's not available till at least April 26th
    03-27-2016 12:34 PM
  2. sangs's Avatar
    Hi All:
    thanks.
    Had two of the new Samsung angled fast-charge wireless chargers and ended up returning them both, as it was a battle to get them to recognize the phone with even a thin case on it. Have since purchased two of the older Samsung flat chargers (at $22 each, brand new), non fast-charging - and they work perfectly. If I need a fast charge I'll just plug it in.
    03-27-2016 01:16 PM
  3. jexx's Avatar
    I have both and don't notice any difference in performance at all. I happen to like the new, tilted one better, easier to see what may be going on with the phone, just my opinion....To clarify these are Samsung OEM fast chargers that I have. My device has a Tech21 case on it.
    03-27-2016 01:18 PM
  1. Verizon vs. Sprint
    By bittersweetsailr in forum Verizon
    Last Post: 04-06-2016, 08:49 PM
  2. charging issue
    By Mblanda in forum LG G4
    Last Post: 03-27-2016, 10:57 AM
  3. Moto G2 battery drain and taking long time to charge suddenly
    Last Post: 03-27-2016, 08:42 AM
  4. LTE speeds ATT s7 vs international; just wondering
    By godofdeath in forum Samsung Galaxy S7
    Last Post: 03-27-2016, 07:42 AM
  5. Droid Turbo and Toyota Tacoma Wireless Charging Pad
    By Taco75 in forum Ask a Question
    Last Post: 03-26-2016, 09:17 PM
