kanyewesttx
Active member
even though i don't really use the s-pen, i'm waiting for the note 6 cause it always has the "latest and greatest" btw I'm sattisfied with my Nexus 6p its great
With the SD Card Notification problem apparently still not root caused, may want to hold off on the S7 edge.
http://forums.androidcentral.com/sa...ard-notification-keeps-popping-up-help-6.html
I am interested in the note as I absolutely loved my Note 5, but I feel we will see something similar to last year. The 5 took the best of the S6 and slightly enhanced it, curved back and more memory.
With that said I think we will see this again, so a Note 6 with the 820, IP68, same Sony IMX240 but a small bump to 6g of ram and an even bigger battery maybe 4000mah and probably a base of 64g of storage, maybe USB type C.
Other than that I don't think we will see much.
It'll probably have the same mantra as the S7, if the Note 5 is any indication.I am interested in the note as I absolutely loved my Note 5, but I feel we will see something similar to last year. The 5 took the best of the S6 and slightly enhanced it, curved back and more memory.
You may be thinking about the Samsung Galaxy S7 because the Galaxy S7 Edge has a bigger battery and most definitely gives you awesome screen on time. I will usually get 7 hours screen on time but sometimes even closer to 8. Never 4 to 6 that's for sure.The SoT you're suggesting is mostly wishful thinking. The battery on this is amazing and a clear step up from the S6, but SoT is averaging 4-6 hours. Sure, there are rare times when you can get a bit more than that but for average use this is what a prospective buyer should expect.
I'd find new sources to read if I were you.I read some predictions of Note 6 with 5.8 inch screen including 256gb built in sd and 6 gb internal memory using Android N in the $1200 range. Supposed to be a real pocket computer.
