View Poll Results: Wait or pull the trigger?
Voters
35. You may not vote on this poll
  • Pull the trigger on the S7e
    12 34.29%
  • Wait for the Note 6 if your phone can make it. Then weigh your options.
    23 65.71%
04-15-2016 03:53 AM
89 123 ...
tools
  1. D13H4RD2L1V3's Avatar
    Alright, let me explain my dilemma right now.
    Many of you know my current daily driver is an LG G4, which I loved a whole lot until recently. My original unit died to the bootloop issue when it was just 6 months old. It's been replaced with a newer unit that's now 3 months old, but has started chalking up issues, namely overheating and unexplained battery drain that causes the phone to die off quicker than normal.
    As such, I have decided to replace the phone with a totally different phone from the current year. After some research and evaluation of my usage pattern, I decided on the Galaxy S7 Edge as it has a large battery and expandable storage that suits my usage pattern perfectly. Add in great performance, a stellar camera package and other stuff like Samsung Pay and it's already set to be my next daily driver. Except for one thing.
    I have always loved the Note series. In fact, I'm more fond of the Note-line compared to the S-line. I love the S Pen and what it does and I also love the focus on productivity when it comes to what the Note is made for. So naturally, I'm excited for the Note 6. But I'm not sure if I should wait a few months for the Note 6 or just get the GS7 now.
    It's easier said than done. I would LOVE to wait for the Note 6 as I really love the Note-line as a whole (even though I think the 5 kinda missed the mark, although it is still a great phone) but I'm not sure if my G4 will survive past July as it seems to be exhibiting the same issues that struck my old unit before it died.
    So what do you guys think?
    Also, curved screen or S Pen?
    03-27-2016 01:35 PM
  2. flintlock's Avatar
    I have a S7 E on order but the non removable battery and the glass back are negatives. The larger battery is good but it's not that hard to charge mid day of you need to. It is hard to change your non removable battery when after 18 months it's not holding a charge that we'll.
    The new G5 isn't available to hold and see yet but the ability to replace the battery and the metal back look good. The modules seem a gimmick to me. They'll probably be orphans when you replace the phone.
    Decisions decisions.
    03-27-2016 01:43 PM
  3. D13H4RD2L1V3's Avatar
    The removable battery doesn't matter as much to me since the phone will last all-day anyway.
    And I'm actually not fond of the G5, particularly due to its battery size and my skepticism of LG's QC after having 2 failing G4s.
    03-27-2016 01:46 PM
  4. sfla99's Avatar
    I do not think battery is of any concern with this ohone, most are averaging 6-7 SoT and some are getting 8-9 on a single charge.
    If you need more than 8 hours screen time on a single charge then I do not know what to say, but the battery is no joke amazing in the edge with little effort to get the best out of it.
    03-27-2016 03:23 PM
  5. Gator352's Avatar
    If you can live without the s pen, go with the s7e....NOW!
    I had the note 3 and 4. I loved them. I used the s pen often but then i decided i needed a smaller phone because using two hands all the time got tedious. So i got the s6 and now the s7e. I don't miss the s pen at all now whatsoever so I'm good!
    lang007 and CTgirl509 like this.
    03-27-2016 05:41 PM
  6. Iva_LadyDiCaprio98's Avatar
    I currently own the Samsung Galaxy S7 Edge and I am grateful to have gone with this choice - I was originally going to wait for the Note 6 to come out but my co-worker managed to get hers early and upon having seen it in person, I just had to have it. I was coming from a Galaxy S5 so I was instantly amazed. I don't necessarily need the S-Pen, just wanted something with a bigger screen and the S7 Edge just does it perfect for me.
    03-27-2016 06:29 PM
  7. felloffthetruck's Avatar
    LadyD, what you doing for a screen protector now that scrapped the Bodyguardz?
    03-27-2016 07:16 PM
  8. jlczl's Avatar
    To the OP. I have always had Note devices with the exception of the Note 5 because of the lack of SD card slot and other missing features. This year I bought an iPad Pro and it has filled my note taking needs that used to be filled by my Note phones. I know you also have an iPad Pro from other posts you have made so I recommend getting the S7e. That's what I've done and am not regretting it one bit.
    My daily carry devices are my S7e, my iPad Pro and my Note 4 (which is my very capable backup now).
    03-27-2016 08:02 PM
  9. munnarg's Avatar
    I find them to be two different devices altogether, so it's really based on your usage patterns and what features mean the most to you.
    03-27-2016 08:10 PM
  10. D13H4RD2L1V3's Avatar
    Yeah, I have the iPad Pro, but I didn't buy the Pencil, because I thought it was too expensive for how often I'm going to use it.
    That's why I'm seriously considering the Note. Because it has a passive Wacom-based stylus and digitizer, the stylus doesn't need any batteries and offers nearly the same amount of precision and pressure inputs. Not to mention it's part of the phone itself.
    In fact, I'm actually more fond of the S Pen than the curved edges, but the one on the S7 is seriously improved to the point where it's actually hard to choose between them.
    I'm gonna have to spend more time with it in stores to really think about it.
    03-27-2016 09:27 PM
  11. Kevin OQuinn's Avatar
    Pretty sure the Note stylus is active.
    If you like the stylus so much why did you not get the Note 5?
    03-28-2016 12:26 AM
  12. D13H4RD2L1V3's Avatar
    Many actually have already asked me why I didn't just get the Note 5 now.
    To which I will reply, "No expandable storage".
    And really? I thought it was passive since it didn't have electronics in it, or so I thought.
    03-28-2016 12:37 AM
  13. Kevin OQuinn's Avatar
    Fair enough.
    I personally don't think the Note 6 will be vastly different from the S7e. Bigger, flat screen. Maybe a larger battery. Obviously the stylus.
    03-28-2016 12:44 AM
  14. D13H4RD2L1V3's Avatar
    Fair enough.
    Yeah, I'm eager to see how's the battery life. I mean, the Note 5 did last quite long considering the battery size. Just interested to see if the Note 6 will get an insanely larger battery.
    03-28-2016 12:53 AM
  15. bembol's Avatar
    I'll take the Edge features over the S-Pen.
    I love the changes Samsung made with it.
    I had the Note 5, Samsung's test drive for 1 month and barely used the S-Pen. The last time I really used it was back with the Note 3.
    03-28-2016 03:26 AM
  16. Iva_LadyDiCaprio98's Avatar
    At the moment I don't have a screen protector on. I might stop by AT&T and get the Zagg HD instead but not sure as I had that one as well but it wasn't placed right. Or I might wait until there is a decent tempered glass available.
    03-28-2016 09:01 AM
  17. lang007's Avatar
    I am in the same boat torn between my Priv or upgrade to the GS7E
    03-28-2016 11:11 AM
  18. Almeuit's Avatar
    If you actually use the S-Pen .. I would say to stay with the Note 6. The curve is nice but that is about it .. nice. It has minimal uses (I am training myself to use them) but if you want usability (and use it) the S-Pen will trump this everytime.
    wlonsdale likes this.
    03-28-2016 12:10 PM
  19. LeoRex's Avatar
    I'd say if you want a Note, wait for the Note. If history is any example, the Note will most likely be a better phone than the S7 or S7E.... at least it's been the case for the previous 3 or 4 generations.
    03-28-2016 02:05 PM
  20. bable's Avatar
    A point that got me to wait was update cycles. The note might come with android N, and even though it probably won't it'll still be updated before the s7. That got me to cancel my preorder and then the locked boot loader kept me from placing a new order. I'm on T-Mobile so if I grabbed an s7e then I'd probably see android n in late 2017
    03-28-2016 09:21 PM
  21. PsychDoc's Avatar
    The SoT you're suggesting is mostly wishful thinking. The battery on this is amazing and a clear step up from the S6, but SoT is averaging 4-6 hours. Sure, there are rare times when you can get a bit more than that but for average use this is what a prospective buyer should expect.
    03-28-2016 09:28 PM
  22. Kevin OQuinn's Avatar
    Unless Google radically changes the release schedule for Android with N the Note will not come with it. It'll come with what we have on the S7e.
    Almeuit likes this.
    03-28-2016 09:42 PM
  23. D13H4RD2L1V3's Avatar
    I thought that rumor was a bit of a stretch.
    The N6 is rumored to release in July. Google I/O 2016 is on May 18-20, which is where we'll see Android N in further action.
    Even so, assuming N is released by then, I'm not sure if Samsung can make TouchWiz work on it fast enough before the launch of the Note 6.
    Then again, there is a possibility that Android will split into a Google-controlled backend and a Samsung-controlled frontend to speed up OS updates while allowing Samsung to do their thing.
    03-28-2016 11:37 PM
  24. cardboard60's Avatar
    Bought the S7E
    Will wait to see what the Note 6 brings. If I like it that much I might consider buying it too.
    03-29-2016 01:48 AM
  25. shadoweave's Avatar
    If you prefer the Note 6 then you should wait for it. A little bit of patients can avoid some anxiety at having jumped the gun and got something that you don't like as much
    03-29-2016 05:17 AM
89 123 ...
  1. Erratic battery level indications on Galaxy S3 mini
    By sfisbein in forum Samsung Galaxy S3 Mini
    Last Post: 04-01-2016, 02:51 AM
  2. I'm having a strange problem with my Note 5
    By Rmbrown1964 in forum Samsung Galaxy Note 5
    Last Post: 03-28-2016, 02:27 PM
  3. Android 4.4 on LGL34C keeps turning wifi off when in use
    By AC Question in forum LG Optimus Series
    Last Post: 03-27-2016, 06:10 PM
  4. [Galaxy 551] How can i fix insufficient storage space on google play?
    By AC Question in forum More Samsung Phones
    Last Post: 03-27-2016, 05:39 PM
  5. Has anyone gotten the Elephone M3 yet?
    Last Post: 03-27-2016, 01:28 PM
