1. soky001's Avatar
    Did anybody tried to set the AOD only to "ON" when loading in Dock over night? Tried to adress it with Automagic app to set this automatically but no succes, anybody got another idea?
    03-27-2016 12:42 PM
  2. mr_phillip's Avatar
    No go with AoD.
    But use Chronus or Dashclock Widget, and use it in Daydream to light up when docked. That's the perfect replacement.
    03-27-2016 01:10 PM
  3. soky001's Avatar
    Wait going to try right away, had the same idea and tried with Timely but did not like the night clock, thanks for the quick reply...AOD would be the most elegant and nice solution, maybe Samsung should continue listening to us customers...
    03-27-2016 01:16 PM
  4. KPMcClave's Avatar
    It isn't automatic, but it would at least be easy to use the AOD toggle above the notification shade. Toggle it on at bedtime and off when you get up.
    03-27-2016 02:30 PM
  5. maf113's Avatar
    not sure if this would work. but you could program a NFC tag to toggle on/off AOD on the dock or next to it.
    03-28-2016 04:02 PM
  6. soky001's Avatar
    Thx maff no bad idea, but the reason to load AOD only at night from my point was not to use AOD during the day to save some battery power, and during the night i love to have a nighstand watch in case I want to take a peak on the clock. If I use NFC, which I usually do not use because this is a battery draining option too, this would be one step forward and one step back.
    @KPMcClave...like your easy solution, would be perfect if it would do automatic, but the manual variant is a good idea
    03-28-2016 04:52 PM
  1. Pull the trigger on the GS7 Edge or wait it out for the Note 6?
    By D13H4RD2L1V3 in forum Samsung Galaxy S7 edge
    Last Post: 04-15-2016, 02:53 AM
  2. Erratic battery level indications on Galaxy S3 mini
    By sfisbein in forum Samsung Galaxy S3 Mini
    Last Post: 04-01-2016, 01:51 AM
  3. Android 4.4 on LGL34C keeps turning wifi off when in use
    By AC Question in forum LG Optimus Series
    Last Post: 03-27-2016, 05:10 PM
  4. [Galaxy 551] How can i fix insufficient storage space on google play?
    By AC Question in forum More Samsung Phones
    Last Post: 03-27-2016, 04:39 PM
  5. why did my video shoot upside down on S6
    By sophiegriff in forum Samsung Galaxy S6
    Last Post: 03-27-2016, 04:20 PM
